Expedition rack and ladder questions
Battery to circuit and took two black wires through the A-Pillar and up the crack that goes to the inner roof rack. I bought small rubber seal that coves it completely, then up the side mount of the roof rack and over. From the circuit inside, I took it across the inside of the hood, under all the plastic, and took a positive through the side A-pilar, inside the door and into the cubby area where I mounted a round switch- Its not perfect but I couldn't find a port into the cabin from the engine bay....
![](https://cimg5.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/img_2268_a6b3d33e1e615c776cfe30976a0f1a9697963de4.jpeg)
Black helps, but you'll see in the crack above the pilar a wire fit down in there - I put two separate wires instead of one combine.
![](https://cimg7.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/img_2267_cc9760de0fdeea70f538d060f6c32a9c833d34d5.jpeg)
As you get towards the rack, I used 2inch gloss black vinyl to cover the wire to the rack
Guapo (10-30-2020)
