I can't believe I forgot to post this here, but about six months ago, I decided to cut a hole in the plastic panel to expose the front recovery point. I am not a huge fan of how the OEM front undershield looks, nor was I willing to pay $3,700 for the part and labor that my dealer quoted me for the install, so I decided to take the matter into my own hands. I measured the panel, and drew a square to cut out. The sides are both 14 1/2" from the sides of the panel and 3 1/4" from the top and bottom of the panel. I then used a Sawzall to cut the hole and wrapped some trim around it. to reinforce the plastic trim on the bottom, I screwed in an aluminum bar to strengthen it. I think it turned out quite well! Six months later the trim is still on there and looks as good as they day I installed it!
any images of the reinforcement bar you added, trying to understand what you're referencing. Thanks for sharing
I don't have any photos unfortunately, and I had to get a new front panel after removing the last one and breaking some of the clips in the process. I cut a new hole, but didn't add the aluminum bar on my new one, as it wasn't necessary at all. But what I used was just a 1/8" thick aluminum bar from Home Depot, and cut it down to evenly fit across behind the bottom of the panel and then screwed it in.
I will say, you have enabled your recovery point access but that hideously expensive and invasive to install $3700 LR plate also provides another function which is as a bash plate. If you’re going to do hard trails, you might want to consider a bash plate up there. The LR one does more than just make the recovery point visible -- mine has battle scars after several years of offroading. It’s gnashed and has taken a beating. It’s extremely tough and durable.
If you don’t want to spend the money, that’s fine, but to say that you’re not a fan of something that looks great is a lame excuse not to do it properly.
I went with a chinese skid plate and installed it myself. Was certainly a PIA, but at the end I’m very satisfied.
I think like almost all the off-road oriented accessories that actually benefit the user when off-road, the OEM bash plate has been discontinued and/or baked into some front end protection garbage at a whopping fee. It was $1000 port installed when I got mine in 2021. Now it's about the cost of a good front metal bumper and winch cradle. Pass.
Good plate. I'm on my second. They take a beating well.
