Extended Fender Flares US Spec
Old Sep 1, 2023 | 11:58 AM
  #31
starbai's Avatar
Originally Posted by sarek
i installed the euro flares vs the NAS. I like that it looks more like the classic defender flare without the marker lights.
Did you also just wrap up the connectors and tuck them away? anything special to keep em' safe/away fromt he elements since they will remain 'hot' when the lights are on?
Old Sep 5, 2023 | 10:31 PM
  #32
Ehloo's Avatar
i wrapped them in a plastic bag and taped them really well then put another bag on top of them and then tapped them really well. i doubt water will get in unless submerged
Old Mar 26, 2024 | 12:02 AM
  #33
longtrip68's Avatar
Originally Posted by hoss_vw
I may wait until next week for the adhesive to fully bond.
Does anyone know if the bonding adhesive used to attach the arch extensions is permanent? Will it cause paint damage if arch extensions were to be removed later? I purchased at certified preowned defender that the previous owner added these rock chip guards. I don’t mind them, but would have to remove them in order to add the arch extensions discussed here. I believe they might use the same bonding adhesive and obviously don’t want to cause paint damage if I pry them off. Thanks for any knowledge!
Old Mar 26, 2024 | 01:51 PM
  #34
Husky44's Avatar
It's 3M red double-sided tape. No problem removing, relatively easy cleanup.
Old Mar 28, 2024 | 09:50 PM
  #35
Chrisbob's Avatar
Default heat
Heat up those panels and pull them off slowly. Use some adhesive remover to clean up any residue.
[/QUOTE]
razorkill12
Jun 11, 2018 09:41 AM
smkbronco
Detailing
Aug 9, 2009 08:11 PM
herblatham
Appearance & Camping Set Ups
May 13, 2008 03:47 PM
fanatic516
Aug 17, 2007 11:17 AM
