Factory tire air compressor
Old Aug 2, 2023 | 01:44 PM
DefenderSISU's Avatar
Default Factory tire air compressor
I had a E2 code on my air compressor in the boot and I took it apart and found that it was a connection had come undone. Plugged it back in and everything is working properly. Just a heads up.
Old Aug 2, 2023 | 03:19 PM
nashvegas's Avatar
Thanks. I've had E4 a few times which meant something along lines of "pressure mismatch problem" and software updates fixed it.
Will keep an eye out for E2.
Old Jul 30, 2025 | 06:00 AM
MiltonMan's Avatar
Thanks for posting. I had the same issue, plugged the small 3 pin connector back in, easy fix👍
Old Jul 30, 2025 | 08:54 AM
wcc18999's Avatar
I think what happens with continued use of the factory air compressor, the vibrations will cause the plug to loosen up and disconnected. Happened on multiple occasions during a Land Rover customer experience trip.
Old Jul 30, 2025 | 04:19 PM
MiltonMan's Avatar
Makes sense. Mine was first use so unsure if was ever plugged in or worked lose over the last 3 months.
Old Jul 30, 2025 | 04:43 PM
nashvegas's Avatar
That’s why these boards are great !
Ericlockheed
Dec 19, 2022 08:58 AM
zacharyz28
Dec 29, 2021 09:46 PM
Avs2021
Jul 2, 2021 12:11 PM
PurpleRain
Aug 23, 2020 12:32 PM
05TurboS2K
Aug 7, 2019 07:47 PM
