Finally, new Defender coming home tonight
Old Jan 3, 2021 | 12:10 PM
  #21
SmokinV10's Avatar
Originally Posted by crewcabrob
Hi,
I wanted a wheel that looked like it should be on a Rover, and the Hercules looks very similar to an OEM wheel. That being said, finding any Redbourne that will fit, is a bit of a challenge. I was lucky to find a set of 5 available. With a 32mm offset, I felt it was better for a wider tire than the 25mm offset of other Redborne wheels.
To run a 33 x 12.5, you will have to run a lift larger than 1" Even then, you will get very mild rubbing on the inner wheel well. This can easily be resolved with a heat gun or Dremel tool and some trimming. I have not addressed mine with the heat gun, frankly I'm waiting until some warmer temps to fix it.
Rob
My tire is 1.5” less wide but it’s taller. It’s a BFG KO2 in 275/60R20. Fits fine with the OEM wheels and the Johnson 1.5 lift rods. Ordered the 2” from lucky 8 but they turned out not to be in stock (lucky 8 seems to have trouble understanding their inventory). Someone here said 2” lifts suffer in ride quality too. With the Johnson rods, I know it rubbed with a 25mm spacer on the OEM wheels. Since the 25mm offset on the Alstons are essentially splitting the difference between the OEM 41.5 offset and 25 I’m hoping it works. I only ordered one wheel to try. Alstons were out of stock for the last two months - looks like a batch is coming in now. There’s only 3 Hurcules wheels in stock- 2 short of a set.
Old Jan 4, 2021 | 07:56 AM
  #22
crewcabrob's Avatar
Originally Posted by sblvro
Did you buy a C8 too? Your name rings a bell?
Hi,
No C8 interest... Its been a long time since I have had a toy car in the fleet.
I've been using the Crewcabrob name on all forums since early 2000. In 2000, I bought a Supercharged Nissan Frontier 4x4 Crewcab. Fun little truck to do the family chores. I just keep using it because I can easily remember it at my age.
Rob
Old Jan 4, 2021 | 08:03 AM
  #23
sblvro's Avatar
Hi,
Rob
Oh ok. I just saw another Rob who like redbourne wheels in his C8. Also from TX.
Old Jan 4, 2021 | 06:11 PM
  #24
crewcabrob's Avatar
The extra width on my tire is the primary reason it rubs. I only went up .7" in height, but the tires were much wider. The way mine rubs with the 32mm offset of the Hercules wheel would be worse with the 25mm offset of the Alstons you are looking at. I wanted a wheel that got me away from using a spacer, so the 32mm offset was about as perfect as I could get.
The wheels are going to be much harder to get now that Defenders are being modded. I actually considered I might have to buy silver Hercules wheels and have them powder coated black. I was lucky and found the set I needed.
Good luck!
Rob
Hunter Evans
Defender
Jan 23, 2021 12:21 PM
sblvro
Oct 24, 2020 07:11 PM
Harden Ervin
Jul 30, 2019 01:11 PM
sn1987
Defender
18
Aug 27, 2009 03:27 AM
