Finally pinpointed and fixed a creaking noise - fix inside
Old Dec 29, 2020 | 08:43 AM
JesseRohr's Avatar
Default Finally pinpointed and fixed a creaking noise - fix inside
Morning Forum Friends,
I have had this noise coming from what I thought was the headliner (inside) that was driving me bonkers when temps dipped below 40 or so degrees here. After many failed attempts to isolate the noise I finally found it by accident while adjusting something on my roof rack.
The trim plastic part most rear of the vehicle above the rear tailgate door touches the roof panel which is metal. When the vehicle articulates/flexes when cold the two pieces make the clunky/creak noise that was driving me insane and was very audible inside. The dealer was unable to locate the noise because they would never drive it when it was cold enough to happen.
So having had a G-Wagen before and knowing that dry lubes work awesome to remedy noises on those creaky bastards I used a product I used on that (intended for bicycle chains) and the noise has been gone ever since.
If you're trying to replicate the noise yourself here is a trick. Grab the rear part of your factory roof rails and give the car a good shake from that point rocking the car back and forth. If yours has the noise you'll hear it right away and it will be obvious where the contact is between the two panels.
Your weapon:
Repeat on other side if needed.
Old Apr 10, 2025 | 01:40 PM
lightning's Avatar
Thank you for the advice it's worth knowing.
Old Apr 10, 2025 | 07:47 PM
nashvegas's Avatar
Great tip.
Also. I wish mine were that shiny and clean. Um. Nice.
Old Apr 10, 2025 | 10:05 PM
Vadiable Paradox's Avatar
Careful when ordering.
There are two products at Amazon:
Different bottle. Same size. Same UPC.
2020Defender1stEdition
Jan 17, 2022 09:55 AM
garywwood
LR4
Aug 12, 2020 08:32 AM
landroverdude
Mar 12, 2020 05:12 AM
KernowDiscovery
May 30, 2014 10:44 PM
pickps
May 14, 2007 12:42 PM
