Front Expedition System
Would you consider getting a winch? Then there is a metal winch tray, front metal with a winch fairlead, and a couple of vertical metal bars.
I've got the Trophy Ed and this is what my front looks like:
https://www.carscoops.com/wp-content...-Edition-1.jpg
Pretty sure it's plastic, not 100% but 90%.
Huc (07-28-2024)
Last question for me, are those "raised corners" indeed raised significantly enough to make a difference in clearance?
I wish there was a high res picture but no, all I can find is "fade into black". Another quick search, another question just like that here, and a nice picture: https://landroverforums.com/forum/20...e4/#post902213 (and here's the picture link from that post, not to get up twice).
So, does it provide better clearance, or just a different look? Also, it looks like FEPS has replaceable outward positioned bottom parts which would take less money and effort to replace - assuming they are sold separately, I wasn't able to find the part number yet. Good question to a dealer, asking now.
But that is just my opinion.
curb-optional (07-31-2024)
Having spent a few more hours on research and having stumbled upon the shop manual in the meantime, I agree with you firmly. Reason is, FEPS, as it turns out, is not a part-by-part change, but a cut-and-slap-together change. You actually have to cut live healthy pieces of the original vehicle to slap FEPS on it. I know now it's a port install option, I have no idea whether they have custom template cutters to do this or do it by eye, but the whole idea is repulsive to me, so hard no. That, by the way, explains why those parts are so expensive - they're custom.
The only thing I have to come to peace with is that this apparently a dealer installed option, and hence a) risk, and b) unclear if it is covered by any warranty. Might as well DIY it, now the choice is whether I want to go full Monty and install the JLR part, or go with the "easy install" one.
If you look at the shop manual (someone on here posted the multi thousand page PDF a while ago) you will see that the standard parts have cut lines molded onto the back surface. Smart design negating the need for templates. I’m still not ready to take a dremel cutting wheel to my 2022 under warranty vehicle though
That almost settles it.
https://www.defender2.net/forum/topic83517.html
There has to a be a set somewere out there, please let me know - Thx.
I'am searching this part for over 2 years on Defender2.net
