Front / Rear Weight Distribution
Old May 30, 2023 | 09:41 AM
POPTOPP's Avatar
Well, it you want to know the actual axel weights and not the axel ratings, take your Defender to a truck scale. Scales here in the US have 3 platforms - steer, drive and trailer. Is that not the case elsewhere?
Old May 30, 2023 | 10:48 AM
mzeee's Avatar
I read it as distribution per axle and not maximum weight for each axle. Sports car stuff.
Op had best at least make up a rock lady story now if it didn't really happen. Would be too much of a let down with all thos build-up.
That's the maximum weight per axle.
I know I can go get it weighed, but I was hoping to avoid something like that. Perhaps someone else already has.
As for the stories you invented to explain my absence over a holiday weekend, just after I asked about the cargo capacity of my Defender... I can't help you with your overactive imagination.
Old May 30, 2023 | 05:49 PM
POPTOPP's Avatar
Originally Posted by mzeee
I'm trying to calculate for front and rear axle weight maximums, but can't really do so unless I know the front and rear weight distribution, or axle weights when empty. I have the curb weight from the manual, but don't know how it's distributed front and rear. Does anyone know?
Guess I'm confused. You're asking for front and rear axle weight maximums which would be the GAWR listed on your data plate. Are you asking for the axle curb weights? If so, you really need to take your Defender to the scales. Most everyone has different configurations and loadouts which would not be applicable. For example, my 110 weighs in as front axle at 3075 lbs and rear axle at 3045 lbs. But I've got sliders and moved my spare to the roof rack.
Old May 31, 2023 | 04:54 PM
mzeee's Avatar
That's a little shocking. That's almost 1000 pounds over the published curb weight of a 110. Why?!
Old Jun 1, 2023 | 08:18 AM
POPTOPP's Avatar
That 5035 lb curb weight for a 110 P400 is for a base setup. Add a lb here and there and soon you end up with quite a bit more as the true curb weight for your specific configuration and load out. In my case, let's start with me - I'm quite a bit heavier than the 150 lb allowance for the driver. Now, the options I have: air suspension, tow hitch and custom strengthening bar, front under shield with its heavier support bar, rock sliders, roof rack, panoramic roof, tire inflator, recovery gear (straps, shackles, come-along, and boards), GRMS radio and all of the other miscellaneous crap that is permanently stored in the truck. It all adds up real fast. The good news is that the truck still has for me a reasonable payload remaining of over 850 lbs.
Xploit
Jun 20, 2024 10:28 AM
mfallucco
Dec 3, 2022 10:59 AM
XRAD
Apr 27, 2021 09:37 AM
whiterabbit
Oct 14, 2020 03:18 PM
flabrit
Apr 26, 2013 12:47 AM
