Front rubber LR floor mats suck
Old Jan 14, 2023 | 04:17 PM
  #31
WTFChuck's Avatar
The genuine LR front rubber mats leak water through the mounting pin holes... so water leaks thru the floor mat onto the rubber flooring, cannot evaporate since it has a rubber mat on top, and in my case then sat here since my offroading trip in early December.
Note: pulled up the side panel and under seat access cover by the subwoofer, water does not appear to then be going thru the mounting pegs onto the metal floor below which was my fear.
The mats were bone dry on top, the underside was a mildewy wet mess.
How is that a good thing / how on earth they designed them this way is beyond me.
Anyone know if other aftermarket mats still leak through their mounting points as well? (taxmat, weather tech (which I think look tacky)..., etc?)
Water pools in here, as it is supposed to, then leaks through these round mounting holes. As a test, tried filling up the mat with water on our outdoor table and it steadily dripped out of both mounting pegs.
This is all from the mat itself, not a leak in the car
A little confused by the pics shown here. They appear to be two different brands/types of mats. The first shows a Land Rover logo, the second doesn’t. Is this a comparison? And if so, what is being compared? The first also shows some type of cap over the mounting stud, the second doesn’t. We need a little more info, please.
Old Jan 14, 2023 | 04:19 PM
  #32
Nuckle's Avatar
Second pic is the floor of the defender with no mat installed.
Old Jan 14, 2023 | 04:22 PM
  #33
Jiman01's Avatar
First is the mat, the second is the actual floor board sans mat showing the wetness that accumulated underneath the mat.
Old Jan 14, 2023 | 04:44 PM
  #34
Blackdirt Cowboy's Avatar
So, all this being said, what floor mats do y’all recommend? My x-dynamic 130 came with the carpeted mats from the factory. The drivers side mat is so small, my feet are bigger than the mat. I would like to replace it with something that will give better protection.
Old Jan 14, 2023 | 05:14 PM
  #35
TeddyG's Avatar
Tuxmat? But showing out of stock on website.....
Old Jan 14, 2023 | 07:01 PM
  #36
RH5555's Avatar
I had some left-over black Devcon Flexane Putty (2-part rubber for mending conveyor belts) which I carefully syringed around the buttons to seal them. No leaks under the mats for me now. But thanks, @nashvegas for the heads-up. I wouldn't have thought to go looking...
Old Jan 14, 2023 | 08:55 PM
  #37
spritekk's Avatar
Default You had me at Tuxmats
Originally Posted by MattF
I've installed Tuxmats - excellent fit and protection so far.
You had me at Tuxmats...Look nice - not available for my 90 yet.
Old Jan 14, 2023 | 09:13 PM
  #38
Yep. Looked into those. Not available for the 130. I’m assuming the 110 mats would fit the first and second rows.
Old Jan 15, 2023 | 08:24 AM
  #39
MattF's Avatar
Are the fronts different between a 90 and 110?
Old Jan 15, 2023 | 11:10 AM
  #40
spritekk's Avatar
Good point...
But fronts only aren't available for a 110. YET? Only front & rear combo..
