Front USB and USB-C Not Working
Old Oct 19, 2021 | 03:33 PM
heidiswiss's Avatar
6th Gear
yes this is happening to me now...no charge in USB-c port.
Old Nov 3, 2021 | 07:50 AM
DPReef's Avatar
Can you provide details on that upgrade to include in car wifi? Thats one thing I really want to do.
Old Nov 3, 2021 | 03:36 PM
rutiger's Avatar
might be a different issue but, this happened to me months back. the backlighting on the panel would also flicker a little bit on vehicle startup.
anyway, i removed the panel & disconnected/reconnected the cable on the back. didn't help. then i did a hard reset of PIVO (hold volume button down for a long time until PIVO reboots) and that fixed my non working USB ports. problem hasn't come back since.
Old Dec 14, 2022 | 11:51 AM
rincos's Avatar
4th Gear
Default Thanks for the fix
same issue ! Thank you for the fix !
works fine , no more problems
Old Dec 15, 2022 | 08:46 AM
nashvegas's Avatar
FYI JLR released a service bulletin on this for the Defenders and a few other vehicles... not sure if this is your issue but see attached.
Seems to be an issue when the illumination goes away on the 2 USB ports.
File Type: pdf
Old Dec 16, 2022 | 04:52 AM
rincos's Avatar
4th Gear
Default Front USB ports interrupting or no illumination
In my case I experienced both power interruptions and no port illumination and the fix for both was extremely easy !!!
System reset by long pressing the power button
Old Jan 12, 2023 | 03:49 PM
john390's Avatar
Hi, I am working on a Velar with the same problem (USB not working and no illumination). I have tried pressing the volume button but to no avail. How long should I press it for as all it does is turn the media on or off. I have tried disconnecting the battery, but no change.
Cheers John
Old Jan 12, 2023 | 05:19 PM
smithbp's Avatar
interested in this too. is the illumination something that is always on… or only at night with headlights?
for some reason i thought min used to always be illuminated, day and night.
will have to grab a cable and test if they are producing power.
Old Jan 12, 2023 | 05:46 PM
smithbp's Avatar
also curious if the passenger side usb-c in the dash is supposed to illuminate. mine never has. it sure if that is normal or not.
Old Jan 12, 2023 | 08:45 PM
nashvegas's Avatar
Hi! No, I can confirm this does *not* illuminate. Wondered the same thing myself awhile back.
