GAP ID4 and Y2026?
Old Jan 29, 2026 | 05:57 PM
erich_aux's Avatar
7th Gear
Default GAP ID4 and Y2026?
Hello. First post.
I am not an owner (but SO is) but am hoping to get on board this year.
i saw on “another forum” that LR will be preventing 2026+ from using the GAP tool.
has anyone else heard/seen anything about this rumor (or fact)?
Old Jan 29, 2026 | 06:01 PM
erich_aux's Avatar
7th Gear
Sorry, just read maybe it’s not an issue any longer. Not sure how to delete a post/thread.
Old Jan 30, 2026 | 01:40 PM
jwest's Avatar
you can edit the post though
Old Jan 31, 2026 | 01:57 AM
L460_Rocks's Avatar
I'll be receiving my Defender 110 V8 in June, not being an issue any longer means the GAP dudes found a solution? Maybe a new version of the tool?
Old Jan 31, 2026 | 02:46 AM
jwest's Avatar
Same tool, updated firmware. Works perfectly on 2026 now.
Old Jan 31, 2026 | 09:13 AM
sarek's Avatar
JLR has apparently introduced a new protocol for 2026 Defender. Basically it's a security protocol that requires the factory Topix diagnostic software to connect to the vehicle. This will only prevent coding and programming from happening with aftermarket tools. This has already been confirmed in Europe that the only method of doing any of the CCF editing that concurrently be done with the gap tool, will only be able to be performed utilizing factory tools. As far as I know, the gap tool should still be able to perform diagnostics as on previous models. It is possible that in time, gap and others may decide to invest in a way to bypass this new security protocol. It looks to be a pretty involved security handshake protocol to allow for coding and programming changes.
Old Jan 31, 2026 | 01:09 PM
jwest's Avatar
Did you not see what I wrote above? GAP already fixed the issue, for my US model anyway.
Old Jan 31, 2026 | 01:41 PM
sarek's Avatar
I did see that. It will be interesting to see when more 26 models come out if this is just a rumor, or a distinct production break month.
Old Jan 31, 2026 | 01:56 PM
jwest's Avatar
If what "it a rumor"? ?Last fall it was correct, GAP couldn't change CCF, but that was then, not now.
Can you explain what timeline you are talking about and where you're getting the information? I ask because two months ago, what you said was correct, the GAP couldn't code the CCF, but then they worked on it, changed the firmware, and now it works fine.
I think it is important to clarify if what you are talking about is just the original old info or something now actually new info - again.
Old Jan 31, 2026 | 02:07 PM
sarek's Avatar
I am not sure if it is the old or new info you are referring to. I am referring to the European info about the MY 26. It is apparently at some production date, they changed their protocols for ccf and programming, not diagnosis. Does your gap tool work with CCF editing on your 26 or is it just functional for diagnosis? If u dont mind me asking, what is the production date of your 26?
