Gas can mount
Old Oct 25, 2021 | 08:31 AM
DefXBill's Avatar
Default Gas can mount
I would like to have a gas can mount attached to my spare tire carrier which would swing out of the way when opening the rear door. Anyone know of any?
Old Oct 25, 2021 | 12:15 PM
GrouseK9's Avatar
BA Tents has a platform you could use: https://badasstents.com/product/ba-t...te-with-strap/
Or if you want to go with Rotopax, they also sell this: https://badasstents.com/product/ba-t...te-with-strap/
If you are willing to go "all in" and mount it to the door, you could go this route: https://www.quadratec.com/products/12232_00_07.htm
Or this: https://www.quadratec.com/p/morryde/...ngler-tj-yj-jk
Heck - just root around Quadratec until you see what you like. Just ignore all the Jeeps in the background https://www.quadratec.com/search/jerry
Old Oct 25, 2021 | 12:51 PM
DefXBill's Avatar
Thank you GrouseK9! This is exactly what I want. Seldom am I off road far enough to be concerned about gas but I have trips in Colorado and Utah coming up and need to open the back door frequently to let my dog out. I didn't want a permanent installation so this is perfect.
Old Oct 25, 2021 | 04:18 PM
DoctorofRocks's Avatar
I'd be concerned about an extra 50-60 pounds weight (with two 3 gallon rotopaxs) on the rear door in addition to the weight of the spare and tire.
I plan on using a mount on the side or roof
Old Oct 25, 2021 | 04:44 PM
DefXBill's Avatar
I decided on this mount, I have Jerry cans. The hinges on the door appear to be robust. I don’t have garage clearance to add a rack on top, and don’t really want anything on the side. After each trip I’ll be removing it for daily driving. Thanks for the input.
Old Oct 25, 2021 | 05:04 PM
umbertob's Avatar
Looks good, until you need that spare tire. Then what?
Old Oct 25, 2021 | 07:07 PM
NoGaBiker's Avatar
This one from MORyde mounts to the wheel itself so should work fine on a Defender. No affiliation, but I used their fender-mount Jerry-can holders for five years on a JK and they are the boss. No drilling or alterations to the Jeep required at all.
MORyde Spare Tire Mount Jerry Can Holder
Old Oct 25, 2021 | 09:01 PM
DefXBill's Avatar
Remove one bolt and bracket with Jerry can slides off giving access to spare.
Old Oct 25, 2021 | 11:18 PM
umbertob's Avatar
I was talking about the Badass Tents systems that rely on a ratchet strap wrapped around a fully inflated spare.
Old Oct 26, 2021 | 01:16 PM
GrouseK9's Avatar
@umbertob - Don't have that set up, but I imagine the process would be:
- Take off cans
- Unstrap mounting system
- Remove Spare
- Change tire
- Put Spare back on back of Defender
- Strap mounting system to deflated tire, synching up tightly
- Put on cans
Is the concern that the deflated tire couldn't handle the strap? Not getting the part that would be a challenge. Me? I'm so pissed off whenever I change a tire I usually toss it in the back of my truck/trunk and flail in all the jacks, wrenches, bits & parts. After I cool down and have the tire fixed, I try to organize it all back in. Usually with less profanity involved the second time. I imagine this being a lot of the same. Other than the added PITA of a deflated tire that I now need to synch tightly because it wants to be deflated. But, I suspect a deflated tire would handle it or the Jeep community would have abandoned this approach long ago.
