Gas Grade and Brand
Old Dec 18, 2024 | 05:09 AM
graym's Avatar
Default Gas Grade and Brand
Just wondering what others are using in their defender...what brand and what grade gas are you using.
Im using Shell nitro
Old Dec 18, 2024 | 05:25 AM
wcc18999's Avatar
Shell Nitro 93 octane.
Old Dec 18, 2024 | 07:44 AM
H1Tad's Avatar
91 or 93 - whatever is available.
Brand is "whatever I drive past when I need to fill up".
Old Dec 18, 2024 | 07:51 AM
CincyRovers's Avatar
I always use premium 93 octane, but I'd say 75% of the time I also use the Shell V-Power Nitro +. I also use Sunoco, as there's a Sunoco station right next to my office, and Kroger. The problem here in Ohio, is that it is one of three states (Nebraska & Alaska being the others) that doesn't require fuel testing, and there have been a few news reports lately of people getting bad gas in my area, but only at crappy Speedway stations. I've never had a problem with the Shell, Sunoco and Kroger stations that I frequent.
Old Dec 18, 2024 | 10:03 AM
Jim 90's Avatar
Shell premium which in my area is usually 91 octane and 10% ethanol. (110X p400 and 90X p400). Sunoco on the turnpikes (only roadside) but is normally 93 octane.
Old Dec 18, 2024 | 10:26 AM
Xtabi's Avatar
I try to use only top tier gas.
https://www.toptiergas.com
Old Dec 18, 2024 | 11:44 AM
RedStickRover's Avatar
8th Gear
I only use Exxon Synergy Supreme+ 93 octane
Old Dec 18, 2024 | 08:53 PM
hi12's Avatar
91 usually from Valero or Costco. Aren’t there like only 2-3 refineries anyway that supply most of the gas stations?
should add… in Jersey I usually only see 87/89/91. Very few carry 93
Old Dec 19, 2024 | 07:24 PM
Jim 90's Avatar
Most of the gasoline, at least in the east, comes through several pipelines and is basically the same. As it arrives at the retail marketers additives are added, usually secret and not transparent. However it is conventially considered to burn cleaner and more efficient. Hence the “top tier” designation. Typically the discount retailers do not add additives. Some believe additives are important and others say gas is gas.
Old Dec 20, 2024 | 10:04 AM
msq17's Avatar
Being in the Northeast, I use 93 or 91 octane, which ever is available. And it is usually either at Irving, Citgo, or Sunoco. If I happen to see an Exxon or Shell, then I will go there instead. Costco gas is also supposed to be good, but the lines are always ridiculously long so haven't purchased Costco gas in a long time. Being from California, I was always partial to Chevron, but no Chevron out here. And always avoided ARCO gas as I got terrible mpg in my P38 using ARCO.
