Goodyear Wrangler Duratrac RTs - 275/55r20 vs 265/55r20
Old May 21, 2025 | 08:36 AM
more snow's Avatar
4wd High
Default Goodyear Wrangler Duratrac RTs - 275/55r20 vs 265/55r20
Goodyear Wrangler Duratrac RTs - 275/55r20 vs 265/55r20.
Which one fits on OEM 20" Rims and does not require Spacers or Lift.
Old May 21, 2025 | 09:04 AM
SilverSFR's Avatar
255 / 60 R20 for sure
275 / 55 R20 mixed results. Very little clearance for any snow, Ice or mud build up without trimming wheel well liners.
Defender Tires Sticky Thread
If you do choose 275 / 55 R20 - Goodyear Wrangler Duratrac RT's please post your findings in the sticky thread mentioned above.
Old May 21, 2025 | 09:19 AM
GavinC's Avatar
275/55 R20 is OEM size option. 31.9"
Many many tires in this size. Many folks run this size. I run this size in my winter set. It is listed in owners manual as a size option (for winter tires) No issues running OEM size tires.
265/55 R20 is the wrong tire. Too small. 31.4" Yes it will fit as it's needlessly too small.
Spacers not relevant here.
Old May 21, 2025 | 09:38 AM
SilverSFR's Avatar
I think this is the Owners Manual reference GavinC is mentioning
Land Rover Defender Tyre Size - Owners Manual
Old May 23, 2025 | 07:47 AM
Darover2's Avatar
I run 275/55-20 which are the same diameter as oem but a bit wider. I also run 20x8.5 whels with +25 offset and zero rubbing anywhere at anytime.
Old May 26, 2025 | 08:03 PM
25Defender110's Avatar
6th Gear
I ran the 275/55/20 Duratrac RTs in the winter this year on my 2025 110, no issues, no rubbing. I live in Atlantic Canada and there were no issues with ice or snow build up or rubbing either, during the winter.
Old May 27, 2025 | 12:33 PM
more snow's Avatar
4wd High
So - Installed Duratrac RTs. and clears on OEM 20's without spacer set.
Raised 275 55 R20 Goodyear Duratracs
Raised Height on- 275 55 R20 Goodyear Duratracs
Access Height Below
Defender 110 L663 - 2023 - Goodyear Duratrac 275 55 20
Old May 27, 2025 | 12:50 PM
Eitan's Avatar
Nice looking rig and thanks for posting the pictures. How happy are you with the Duratrac RT's? Big difference from stock in road noise?
Old Dec 18, 2025 | 08:58 AM
lndrvr90's Avatar
Bumping this thread so see how folks are liking the Duratrac RT. Are you running XL or E rated? TIA
Old Dec 18, 2025 | 09:02 PM
WTFChuck's Avatar
Ditto, I’m shopping for tires, with those on the short list and I’m also interested in owner feedback. Those Wrangler Duratrac or the Nitto Grapplers. Wonder about noise level or drone at highway speed, and load and speed rating.
