Has anyone used GAP iiD To enable in-car wifi?
I know I see the 4G connectivity on the privi screen, but I can't find a Wifi access point from devices in the car. I'm assuming then I do not have this enabled.
Is it possible to enable Wifi in the car with a few edits of CCF or otherwise using the Privi?
If this is done, how does the whole getting 'service' work? I read a thread not too long ago that said you cannot simply just go to ATT or T-Mobile for service. You have to go through JLR. But, if the car wasn't equipped from factory, and I am simply enabling it myself... will they have what they need to 'fund my account'?
Yes I can use my phone for a wifi hot spot, but its PIA to have to turn that on each time, I'd rather just have service work for my wife/kids and their devices.
This is the CCF option list for an L663 pulled from the GAP tool.
Important to remember that not all options pertain to/will work with the vehicle even though they show up on the list pulled from said vehicle.
EUCD-001 Vehicle Type
L663
EUCD-002 Doors
5 Door
EUCD-003 Transmission - Driveline
All Wheel Drive (Without disconnect)
EUCD-004 Bifuel
Not Bifuel
EUCD-005 Engine Type
AJ200P 2.0 litre
EUCD-006 Fuel
Petrol
EUCD-007 Alternator
Alternator 230A
EUCD-008 Steering Wheel Position
Left Hand Drive
EUCD-009 Gearbox
ZF 8 Speed Automatic Gearbox
EUCD-010 Gearbox,Type
Automatic gearbox
EUCD-011 Fuel Tank, Volume
Fuel Tank Small (50L)
EUCD-012 Alarm
Alarm
EUCD-013 Seat Massage
Seat Massage not Fitted
EUCD-014 Headlights, Type
Matrix LED AFS123/IHB
EUCD-015 Headlights, Symmetry
Not Supported
EUCD-016 Dayrunning Light
Standard dipped light. (Non-DTRL)
EUCD-017 Dimmed Dipped Headlights
Not supported
EUCD-018 Foglight Function
Foglight not together with high beam
EUCD-019 Rear Foglight Tow Function
Not supported
EUCD-020 Trailer Module
Not supported
EUCD-021 Keyless Entry And Start
EUCD-022 Additional Heater
Without fuel fired heater
EUCD-023 Cruise Control
Without cruise control
EUCD-024 Rainsensor
Not supported
EUCD-025 Headlight Cleaning
Not supported
EUCD-026 Power Steering Type
Electric Power Steering with external angle and torque control , only for JLR
EUCD-027 Trip Computer
Not supported
EUCD-028 Private Locking, Trunk
Not supported
EUCD-029 Child Lock. Rear Doors
Electrical child lock, rear doors
EUCD-030 Unlock Setting
Two step opening
EUCD-031 Acknowl. Signal Lock/Alarm
Not supported
EUCD-032 Automatic Locking By Speed
Not supported
EUCD-033 Level Sensor - If Alarm
Without level sensor
EUCD-034 Key Lock In Protection2 Ext
Ext scan for key adjacent to tailgate post closure
EUCD-035 Key Lock In Protection Int
Interior Scan for ANY KEY IN VEHICLE to prevent clash of scans between additional key & any key
EUCD-036 Panic Alarm
Not supported
EUCD-037 Blind Spot Information System
Blind Spot Information System With Radar Direct LED
EUCD-038 Road Friction Detection
Not supported
EUCD-039 Ptc Heater (Supplementary Air Heater)
With PTC heater
EUCD-040 Battery Rear
Not supported
EUCD-041 Coupe Filter
Not supported
EUCD-042 Climate Control Unit
3 - Zone ATC
EUCD-043 Speed Limitation
Not supported
EUCD-044 Speed Warning Device
Not supported
EUCD-045 Instrument Cluster Calibration
Not supported
EUCD-046 Wheel Brakes Type Front
Not supported
EUCD-047 Interior Motion Sensor
Without Interior Movement Sensor
EUCD-048 Heartbeat Sensor
Not supported
EUCD-049 Heated Rear Seat
Without Heated Rear Seat
EUCD-050 Telephone
Not supported
EUCD-051 Tyre Circumference
Not supported
EUCD-052 Service Interval
Not supported
EUCD-053 Seat Heat Calibration
Low 38, Mid 42 and High 46
EUCD-054 Heated Front Seats
Heated Front Seats
EUCD-055 Front Seat Ventilation
Not supported
EUCD-056 Callstart Of Parking Heater
Not Fitted
EUCD-057 Parking Brake, Type
Not supported
EUCD-058 Heated Windscreen
Heated Frontscreen only
EUCD-059 Parking Assistance
Without Parking Assistance
EUCD-060 Hill Descent Control
Not supported
EUCD-061 Safety Belt Reminder
Not supported
EUCD-062 Brand
Land Rover
EUCD-063 Frequency- Remote Controls
Frequency 315 MHz
EUCD-064 Air Condition, Rear
Rear End Console with vents
EUCD-065 Glass Type
Standard windscreen glass
EUCD-066 Roof Type
Panorama roof
EUCD-067 Octane Rating
Not supported
EUCD-068 Emission Standard
Not supported
EUCD-069 Body Style
SPORT UTILITY VEHICLE
EUCD-070 Tyre Dimension
Use customer tyre dimension
EUCD-071 Final Drive Ratio
4.1
EUCD-072 Navigation/Traveller Assistance
Not supported
EUCD-073 Loudspeaker Quantities
Not supported
EUCD-074 Suspension
Air Suspension - Four Corner
EUCD-075 Integrated Vehicle Dynamic Control
Not supported
EUCD-076 Towbar
With Trailer Tow Attachment
EUCD-077 Pdcspeakers
Not supported
EUCD-078 Driven Axle
Not supported
EUCD-079 Rear Wheel Type
Not supported
EUCD-080 Wheelbase Series & Extended Length Option
Not supported
EUCD-081 Active Suspension
Not supported
EUCD-082 Steering Gear
Not supported
EUCD-083 Central Lock, Type
Without Burglarproof Locks
EUCD-084 Side Windows
Not supported
EUCD-085 Rear View Mirrors, Outer
With Retractable Mirrors
EUCD-086 Memory Function
Without Memory
EUCD-087 Puddle Light, Outer Mirrors
With Puddle Light
EUCD-088 Auto Lights
Not supported
EUCD-089 Airbag, Passenger Side
Not supported
EUCD-090 Cutoff Switch Passenger Airbag
Not supported
EUCD-091 Side Airbag (Thorax) Driver
Not supported
EUCD-092 Side Airbag (Thorax) Passenger
Not supported
EUCD-093 Language
ENGLISH UK For Instrument and Radio
EUCD-094 El Car Heater
Not supported
EUCD-095 Cupe Ventilation
Not supported
EUCD-096 Collision Mitigation By Braking
Without CMbB-system
EUCD-097 Forward Collision Warning
Not supported
EUCD-098 Lane Departure Warning
LDW Fitted & TSR Fitted with Overspeed
EUCD-099 Park Assist Camera
Without Park Assist Camera
EUCD-100 12 Volt Outlet Luggage
Not supported
EUCD-101 Tyre Pressure Mode System
TPMS With WBL, DLS (Heavy Default) & No HSPA & No WT US
EUCD-102 Oil Level Sensor
Not supported
EUCD-103 Roll Stability Control
Not supported
EUCD-104 El Vacuum Pump, Rear Booster
Not supported
EUCD-105 Wheel Brakes Type Rear
Not supported
EUCD-106 Emergency Brake Light
Without Emergency Brake Light
EUCD-107 Auxiliary Lights
Not supported
EUCD-108 Roof Hatch
Roof Hatch
EUCD-109 Power Windows, Front/Rear
DCU Powered Front & Rear Windows
EUCD-110 Frequency Band & Step, Radio
Frequency Band And Step For USA
EUCD-111 Trimlevel
Not supported
EUCD-112 In Car Entertainment
Low Level Tape + AM/FM Radio
EUCD-113 Voice Control
Advanced Speech Recognition
EUCD-114 Speedo Bias
Not supported
EUCD-115 Speed Lock
Not supported
EUCD-116 Cluster Level
Not supported
EUCD-117 Speedometer
Not supported
EUCD-118 Tachograph
Not supported
EUCD-119 Radio, Amp & Speaker System
Audio High Performance (HP)
EUCD-120 Centre Speaker, Dashboard
Not supported
EUCD-121 Subwoofer
Subwoofer
EUCD-122 Headphone Sockets, Rear
Without Headphone Outlets
EUCD-123 Audio Auxiliary Input
Not supported
EUCD-124 Audio Player
Not supported
EUCD-125 Digital Radio Receiver
Not supported
EUCD-126 Microphone
Microphone (Driver Only)
EUCD-127 Navigation System
Navigation System For NGI
EUCD-128 Parking Brake Switch
Not supported
EUCD-129 Terrain Response Fitment
With Auto Terrain Response
EUCD-130 Pam Scan Pattern
Pattern 1: Core
EUCD-131 Front Passenger Seat Belt Reminder
Not supported
EUCD-132 Driver Knee Bolster
Not supported
EUCD-133 Side Curtain Airbags
Not supported
EUCD-134 Airbag, Driver Side
Not supported
EUCD-135 Front Active Seat Belt Retractor Pretensioner
Passive Seat Belts
EUCD-136 Seat Belt Warning
Not supported
EUCD-137 Left Hand Side Load Door
Not supported
EUCD-138 Right Hand Side Load Door
Not supported
EUCD-139 Rear Opening
Not supported
EUCD-140 Pdcautoactivationmenu
Not supported
EUCD-141 Rear Glazing
Heated Rear Glass
EUCD-142 Roof Height
Not supported
EUCD-143 Rear Wash Wipe
Intemittent Rear Wash Wipe
EUCD-144 Power /Heated Mirrors
Long Arm Power/Heated Mirror
EUCD-145 Auto Relocking
Not supported
EUCD-146 Zonal Opposite Door Relocking
Not supported
EUCD-147 Audible Mislock Feedback
Not supported
EUCD-148 Configurable Unlocking
Not supported
EUCD-149 Homesafe Lighting
Not supported
EUCD-150 Air Quality Sensor
With Air Quality Sensor
EUCD-151 Emission, Evaporation System
Not supported
EUCD-152 Headrests Rear, Folding
Not supported
EUCD-153 External Alarm Unit Supply
Not supported
EUCD-154 Accessory Usb Unit
Not supported
EUCD-155 Traffic Information
Not supported
EUCD-156 A/C Compressor Type
Externally controlled variable displacement clutched (ECVDC)
EUCD-157 Bluetooth Handsfree
Bluetooth Handsfree + Audio streaming + SMS
EUCD-158 Occupant Weight Sensor (Ows)
Not supported
EUCD-159 Rear Belt Detection
Not supported
EUCD-160 Pyro Technical Steering Column
Not supported
EUCD-161 Adaptive Load Limiter Front
Not supported
EUCD-162 Seat Track Sensors
Not supported
EUCD-163 Lap Belt Pretensioner Front
Not supported
EUCD-164 Front Crash Sensing System
Not supported
EUCD-165 Adaptive Ventilation Front
Not supported
EUCD-166 Front Door Warning Lamps
Less Front Door Warning Lamps
EUCD-167 Stall Apply
Not supported
EUCD-168 Key Out Apply
Key Out Apply
EUCD-169 Drive Away Release
Drive Away Release
EUCD-170 Battery Saver Time
Not supported
EUCD-171 Heated Steering Wheel
With Heated Steering Wheel
EUCD-172 Front Centre Mounted Display
Not supported
EUCD-173 Rear Entertainment System
Rear Entertainment System Not Fitted
EUCD-174 Tv Tuner
Without TV Tuner
EUCD-175 Speech Control Language
Not supported
EUCD-176 Door Handle Technology
touch sensor lock and microswitch unlock
EUCD-177 Self Opening Bootlid/Tailgate
Manual Boot Lid (Not Self Opening Boot Lid)
EUCD-178 Shift Indication
Not supported
EUCD-179 Neutral Control Auto. Gear
Not supported
EUCD-180 Rpm Speed Controller
Not supported
EUCD-181 Damp Sensor
Undefined 3
EUCD-182 Asthma And Allergy
Not supported
EUCD-183 Engine Cooling Fan Performance
Not supported
EUCD-184 Global Open/Close
Not supported
EUCD-185 Trip Computer Mixed Units
MPL Units Not Available For Selection By Driver
EUCD-186 Door Remote Control Channel Type
Door Remote Multi Channel
EUCD-187 Audio Buttons, Steering Wheel
Audio Buttons In Steering Wheel
EUCD-188 Handsfree Telemute Function
Not supported
EUCD-189 Shift Into Park Apply
Shift into Park Apply Enabled, Shift out of Park Release Enabled
EUCD-190 Rear Door Sunblinds
Without Rear Door Blinds
EUCD-191 Driver Impairment Monitor
Not supported
EUCD-192 City Safety
Not supported
EUCD-193 Pss Warning Strategy
Dual Level Strategy
EUCD-194 Mirror Mounted Turn Signal
Mirror mounted turn signal
EUCD-195 Hybrid Trip Computer Power Ratio
0.1556 (Full Hybrid Diesel)
EUCD-196 Non-Contact Tailgate
Undefined
EUCD-197 Climate Zone User Layout
3 Temperature, 3 Distribution, 1 Blower
EUCD-198 Eco Info System
Normal Vehicle - US Gallon - 5 Seats
EUCD-199 Nightvision
Not Configured
EUCD-200 Telematics 1
Telematics TCU fitted
EUCD-201 Reverse Gear Chime
Less Reverse Gear Chime
EUCD-202 Solar Sensor
Front - Dual Zone : Rear - Not Fitted
EUCD-203 Telematics Protection
Telematics Protected
EUCD-204 Retractable Running Board
Not supported
EUCD-205 Racing Sub Brand
Mainstream Vehicle
EUCD-206 Driver Workload Manager
Disabled
EUCD-207 Front Camera
Without Front Camera/s
EUCD-208 Steering Column Lock
TPL
EUCD-209 Wade Sensing
(0010) Wade Sensing Fitted - Manual Display
EUCD-210 Battery
Not supported
EUCD-211 Battery Monitor Sensor
Not supported
EUCD-212 Region If Dvd
Not supported
EUCD-213 Eco Data (Driver Information Display)
Function enabled (Display Information level 2)
EUCD-214 Integrated Control Panel
Not supported
EUCD-215 Infotainment Theft Protection
Not supported
EUCD-216 Quiescent Relay Box
BCMLatch function enabled
EUCD-217 Picture Support
Not supported
EUCD-218 Igor System Description
2 Relay with Dumb logic
EUCD-219 Language Region
Without Language Region
EUCD-220 Side Camera
Without Side Camera
EUCD-221 Trailer Tyre Press Monitoring System
Not supported
EUCD-222 Stop/Start
Stop/Start
EUCD-223 Head Up Display
HUD Not fitted
EUCD-224 Adjustable Speed Limiter
ASL fitted
EUCD-225 Advanced Chauffeur Function
AFC not Fitted
EUCD-226 Intelligent Emergency Braking
With Rear only LSIEB
EUCD-227 4X4 Information Display
Enabled
EUCD-228 Audible Alarm Mode
Enabled (Use available sounder)
EUCD-229 Model Year
2023
EUCD-230 Crash Event Data Recording
Undefined error condition if used
EUCD-231 Door Latch Type
Undefined 3
EUCD-232 Auxillary Water Pump
Auxillary Water Pump not fitted
EUCD-233 Part Number Format
EUCD-234 Conversation Assist
Without Conversation Assist
EUCD-235 Navigation Eco Route - Urban Data
EUCD-236 Navigation Eco Route - Extra Urban Data
EUCD-237 Transfer Box
Twin Speed with Controller (low range gearbox)
EUCD-238 Active Roll Control
ARC Not Fitted
EUCD-239 Rear Diff
Rear e-diff fitted
EUCD-240 Ambient Lighting
Not fitted
EUCD-241 Navigation Speed Inhibit
EUCD-242 Passive Locking Error Tones
Chirps off
EUCD-243 Handbook
EUCD-244 Connect And View
CE App Projection Features - CarPlay, Android Auto Fitted Only
EUCD-245 Dynamic-I
Dynamic-i Not Fitted
EUCD-246 Ahb System
Error condition
EUCD-247 Off Road Navigation
EUCD-248 Audio Brand
Meridian
EUCD-249 Video Display Inhibit
Allow video with gear position = Park
EUCD-250 Passenger Seat Module
EUCD-251 Telematics 2
InControl Protect and InControl Connect Pro (Telematics and NGI Connectivity) TCU2 or TCU3(H)
EUCD-252 Alternator : Crank Rotation Ratio
2.8:1
MultiCAN-449 ThirdRowChiller
Not Fitted
MultiCAN-449 InfotainmentType
Not Supported
MultiCAN-449 CameraHMIStrategy
Not Supported
MultiCAN-450 TrunkLmpOutput
Not supported
MultiCAN-450 WindowOpFeedback
No Hall Sensors
MultiCAN-450 WindowCalibration
Not Supported
MultiCAN-451 mPACOS
Without Passenger Airbag Deactivation Switch
MultiCAN-451 DriverPassBeltPret
Without Drv and Pass Belt Buckle Pretensioners
MultiCAN-451 FntDIFbdkMech
BCM receives fault data via LIN
MultiCAN-452 PassOccWghtSensor
With Passenger Occupant Weight Sensor
MultiCAN-452 DriverKneeAirbag
Without Driver Knee Airbag
MultiCAN-452 LeftSideAirbag
With Left Side Airbag
MultiCAN-452 RightSideAirbag
With Right Side Airbag
MultiCAN-453 LeftRearHeadAbag
Without Left Rear Head Airbag
MultiCAN-453 RollOverSensing
with RoSe 2
MultiCAN-453 PADLamp
With Dual PAD Lamps
MultiCAN-454 DeplBatterySystem
Without Deployable Battery System
MultiCAN-454 RightCurtainAirbag
With Right Curtain Airbag
MultiCAN-454 LeftCurtainAirbag
With Left Curtain Airbag
MultiCAN-454 RightRearHeadAbag
Without Right Rear Head Airbag
MultiCAN-455 DriverSwtchLdLimit
Without Driver Load Limit
MultiCAN-455 EventDataRecorder
With Event Data Recorder
MultiCAN-455 PassBuckleSwitch
With Passenger Buckle Switch
MultiCAN-455 DriverBuckleSwitch
With Driver Buckle Switch
MultiCAN-456 CollSteerColumn
Without Collapsible Steering Column
MultiCAN-456 PassAnchorPret
Without Passenger Anchor Pretensioner
MultiCAN-456 DriverAnchorPret
With Driver Anchor Pretensioner
MultiCAN-456 PassSwtchLdLimit
Without Passenger Load Limit
MultiCAN-457 BonnetDepAct
Without Bonnet Deployment Actuator
MultiCAN-457 DepRollHoops
Without Deployable Roll Hoops
MultiCAN-457 RowThreeRestraints
Without All Row 3 Restraints
MultiCAN-457 RowTwoRestraints
With All Row 2 Restraints
MultiCAN-458 AutoSwitching
Auto-switching - enabled
MultiCAN-458 SunsetClause
Sunset Clause - disabled
MultiCAN-458 PedAirbag
Without Pedestrian Airbag
MultiCAN-458 BonnetPyroLatch
Without Bonnet Pyro Latch
MultiCAN-459 MainBeamVoltCtrl
Main beams - voltage control - disabled
MultiCAN-459 DipBeamVoltCtrl
Dipped beams - voltage control - disabled
MultiCAN-459 FrntPosLmpVoltCtrl
Front position lamps - voltage control - disabled
MultiCAN-459 DRLVoltCtrl
DRLs - voltage control- disabled
MultiCAN-460 CornerLmpVoltCtrl
Cornering lamps - voltage control - disabled
MultiCAN-460 FrntDirIndVoltCtrl
Front direction indicators - voltage control - disabled
MultiCAN-460 FrntFogVoltCtrl
Front fogs - voltage control - disabled
MultiCAN-460 AuxFrntLmpVoltCtrl
Auxilliary front lamps - voltage control - disabled
MultiCAN-461 StopLmpVoltCtrl
Stop lamps - voltage control - disabled
MultiCAN-461 RearPosLmpVoltCtrl
Rear position lamps - voltage control - disabled
MultiCAN-461 FrntSidMrkVoltCtrl
Front side markers - voltage control - disabled
MultiCAN-461 StcBendLmpVoltCtrl
Static bending lamps - voltage control - disabled
MultiCAN-462 RearDirIndVoltCtrl
Rear direction indicators - voltage control - disabled
MultiCAN-462 RearFogVoltCtrl
Rear fogs - voltage control - disabled
MultiCAN-462 HiMtStpLmpVoltCtrl
High mounted stop lamps - voltage control - disabled
MultiCAN-462 ReverseLmpVoltCtrl
Reverse lamps - voltage control - disabled
MultiCAN-463 RearSidMrkVoltCtrl
Rear side markers - voltage control - disabled
MultiCAN-463 DRLBehWhilstDIsAct
Turn Off
MultiCAN-463 SeatTrkPostnSensor
Undefined 4
MultiCAN-464 NumPlatLmpVoltCtrl
Number plate lamps - voltage control - disabled
MultiCAN-464 SMBehWhilstDIsAct
No Action
MultiCAN-464 PosBehWhilstDIsAct
No Action
MultiCAN-465 RearAVIOPanel
Not Fitted
MultiCAN-465 PosBehWhilstHazAct
No Action
MultiCAN-465 DRLBehWhHazardsAct
Turn Off
MultiCAN-466 TouchPanel
Not Fitted
MultiCAN-466 RearPosBehWhDIAct
Rear Position Light remains on during DI activation
MultiCAN-466 SMBehWhilstHazAct
No Action
MultiCAN-467 RearDispVariant
Not Fitted
MultiCAN-467 FrntDispVariant
Not Fitted
MultiCAN-468 FntDRLType
Incorporated DRL and Pos
MultiCAN-468 CabinCamera
Not Supported
MultiCAN-468 FrontAVIOPanel
Mid Line Fitted (USB with OTG only)
MultiCAN-469 BluRayRegion
Not supported
MultiCAN-469 OutboardVents
Not Supported
MultiCAN-469 PDCAutoActivation
Not Supported
MultiCAN-470 DRLTransInteraction
Switch OFF in park or neutral
MultiCAN-470 DRLMLSInteraction
Switch off with dip beam lamps or greater
MultiCAN-470 RemoteStartCapable
Vehicle supports RES
MultiCAN-471 PwrTailProxSenPAM
Not supported
MultiCAN-471 MainBeamFdbkMech
MultiCAN-471 LowBeamFdbkMech
BCM receives fault data via LIN + Tell Tale
MultiCAN-472 StealthMode
Enabled
MultiCAN-472 DriverPassRetractor
With Drv and Pass Retractor
MultiCAN-472 BCMCtrlAmbLitSet
BCM does not control default values
MultiCAN-473 PassFrontAirbag
With Passenger Front Airbag Stage 1 & Stage 2
MultiCAN-473 DriverFrontAirbag
With Driver Front Airbag Stage 1 only
MultiCAN-473 QRBPowerPAM
Not Supported
MultiCAN-474 TPMSVariant
Not supported
MultiCAN-474 BumperType
Pattern 3 - Performance
MultiCAN-475 Gracenotes
North America
MultiCAN-475 DLNAStatus
Not Supported
MultiCAN-476 ATPC
HDC and LSPC
MultiCAN-477 RearLoadHeightCtrl
Fitted
MultiCAN-477 FntPosFdbkMech
MultiCAN-477 FntSdMkrFdbkMech
BCM detects faults directly
MultiCAN-478 EDiffMtrBrk
Fitted
MultiCAN-478 CnrLmpFdbkMech
MultiCAN-478 DRLFdbkMech
MultiCAN-479 NavFullMapDisplay
Enabled
MultiCAN-479 RrSdMkFdbkMech
MultiCAN-479 FntFogFdbkMech
MultiCAN-480 EBoxFan
Not Fitted
MultiCAN-480 RrDIFdbkMech
MultiCAN-480 StpLmpFdbkMech
MultiCAN-481 StpLmpOnefail
One fail all fail Strategy disabled
MultiCAN-481 RearFogFdbkMech
MultiCAN-481 RearPosFdbkMech
MultiCAN-482 IntelEmrgBrkingPAEB
PAEB Not Fitted
MultiCAN-482 FntSdMkrDrvMech
Driven via LIN
MultiCAN-482 RevLmpFdbkMech
MultiCAN-483 ATCIPC
Disabled
MultiCAN-483 DRLDrvMech
Driven via LIN
MultiCAN-483 FntPosDrvMech
Driven via LIN
MultiCAN-484 RrPassRrExtDetect
Not supported
MultiCAN-484 FntFogDrvMech
Driven via BCM
MultiCAN-484 CnrLmpDrvMech
Driven via BCM
MultiCAN-485 SideSwipeMitigation
SideSwipeMitigation fitted
MultiCAN-485 HighBeamDrvMech
Driven via BCM
MultiCAN-485 LowBeamDrvMech
Driven via BCM
MultiCAN-486 BrakeOverheatWarn
Brake overheat warning enabled
MultiCAN-486 RrSdMkDrvMech
Driven via BCM
MultiCAN-486 FntDIDrvMech
Driven via BCM
MultiCAN-487 ESSStationSound
Not supported
MultiCAN-487 RrDIDrvMech
Driven via BCM as Stop Light
MultiCAN-487 StpLmpDrvMech
Driven via BCM
MultiCAN-488 ESSSimGearShift
Not supported
MultiCAN-488 RearFogDrvMech
Driven via BCM
MultiCAN-488 RearPosDrvMech
Driven via BCM
MultiCAN-489 ESSPause
Not supported
MultiCAN-489 ExLightingStalkTyp
Momemtary Switch SAE
MultiCAN-489 RevLmpDrvMech
Driven via BCM
MultiCAN-490 IPCOilLvlMenuActiv
Oil level menu not present
MultiCAN-490 FntFogProfile
Diagnostic Profile 1
MultiCAN-491 NavBtnFCIM
Not supported
MultiCAN-491 CHMSLProfile
Diagnostic Profile 7
MultiCAN-492 ExtSyntheticSounder
ESS Not Fitted
MultiCAN-492 FntDRLProfile
MultiCAN-493 NLIAudioAmp
Not supported
MultiCAN-493 FntSMProfile
MultiCAN-494 TrajectoryLines
Not supported
MultiCAN-494 FntPosProfile
MultiCAN-495 P4UBtnFACP
Not supported
MultiCAN-495 FntDIProfile
Diagnostic Profile 25
MultiCAN-496 PassAirbagVent
Without Passenger Airbag Adaptive Vent
MultiCAN-496 RowTwoSquabRelAct
Without Row 2 Squab release actuator
MultiCAN-496 PCMEWULine
PCM Early Wake Up Line Fitted
MultiCAN-497 IntelSpdLimitISL
ISL fitted
MultiCAN-497 DrvDrowsyMonDDM
DDM not fitted
MultiCAN-497 IntelEmerBrkingCUIEB
IEB not fitted
MultiCAN-497 FwdCollWarnAEB
FCW not fitted
MultiCAN-498 Gliding
Not supported
MultiCAN-498 ChauPersonalisation
Not supported
MultiCAN-498 Personalisation
Not supported
MultiCAN-498 LaneKeepAssistLKA
LKA fitted
MultiCAN-499 NGINLIDigRadRecSys
Undefined 32
L663
EUCD-002 Doors
5 Door
EUCD-004 Bifuel
Not Bifuel
AJ200P 2.0 litre
EUCD-006 Fuel
Petrol
EUCD-007 Alternator
Alternator 230A
Left Hand Drive
EUCD-009 Gearbox
Automatic gearbox
EUCD-012 Alarm
Alarm
Not Supported
Not supported
Not supported
Not supported
EUCD-024 Rainsensor
Not supported
Not supported
Not supported
Not supported
Two step opening
Not supported
Not supported
Not supported
Not supported
With PTC heater
Not supported
Not supported
3 - Zone ATC
Not supported
Not supported
Not supported
Not supported
Not supported
EUCD-050 Telephone
Not supported
Not supported
Not supported
Heated Front Seats
Not supported
Not Fitted
Not supported
Not supported
Not supported
EUCD-062 Brand
Land Rover
Frequency 315 MHz
EUCD-065 Glass Type
EUCD-066 Roof Type
Panorama roof
Not supported
Not supported
EUCD-069 Body Style
4.1
Not supported
Not supported
EUCD-074 Suspension
Not supported
EUCD-076 Towbar
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Without Memory
With Puddle Light
Not supported
Not supported
Not supported
Not supported
Not supported
EUCD-093 Language
Not supported
Not supported
Without CMbB-system
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
EUCD-108 Roof Hatch
Roof Hatch
EUCD-111 Trimlevel
Not supported
Not supported
EUCD-115 Speed Lock
Not supported
Not supported
Not supported
EUCD-118 Tachograph
Not supported
Not supported
EUCD-121 Subwoofer
Subwoofer
Not supported
Not supported
Not supported
EUCD-126 Microphone
Not supported
Pattern 1: Core
Not supported
Not supported
Not supported
Not supported
Passive Seat Belts
Not supported
Not supported
Not supported
Not supported
Not supported
Heated Rear Glass
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Key Out Apply
Drive Away Release
Not supported
Not supported
EUCD-174 Tv Tuner
Without TV Tuner
Not supported
Not supported
Not supported
Not supported
Undefined 3
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Dual Level Strategy
Undefined
Not Configured
Not supported
Mainstream Vehicle
Disabled
TPL
EUCD-210 Battery
Not supported
Not supported
Not supported
Not supported
Not supported
Not supported
Without Side Camera
Not supported
EUCD-222 Stop/Start
Stop/Start
HUD Not fitted
ASL fitted
AFC not Fitted
Enabled
EUCD-229 Model Year
2023
Undefined 3
ARC Not Fitted
EUCD-239 Rear Diff
Rear e-diff fitted
Not fitted
Chirps off
EUCD-243 Handbook
EUCD-245 Dynamic-I
EUCD-246 Ahb System
Error condition
Meridian
2.8:1
Not Fitted
Not Supported
Not Supported
Not supported
No Hall Sensors
Not Supported
MultiCAN-451 mPACOS
with RoSe 2
With Dual PAD Lamps
Turn Off
Undefined 4
No Action
No Action
Not Fitted
No Action
Turn Off
Not Fitted
No Action
Not Fitted
Not Fitted
Not Supported
Not supported
Not Supported
Not Supported
Not supported
Enabled
Not Supported
Not supported
North America
Not Supported
MultiCAN-476 ATPC
HDC and LSPC
Fitted
Fitted
Enabled
Not Fitted
PAEB Not Fitted
Driven via LIN
MultiCAN-483 ATCIPC
Disabled
Driven via LIN
Driven via LIN
Not supported
Driven via BCM
Driven via BCM
Driven via BCM
Driven via BCM
Driven via BCM
Driven via BCM
Not supported
Driven via BCM
Not supported
Driven via BCM
Driven via BCM
Not supported
Driven via BCM
Not supported
ESS Not Fitted
Not supported
Not supported
Not supported
ISL fitted
DDM not fitted
IEB not fitted
FCW not fitted
Not supported
Not supported
Not supported
LKA fitted
Undefined 32
Continued...
MultiCAN-500 IntStoreISC
Not supported
MultiCAN-500 IntStoreIMC
Not supported
MultiCAN-500 DistribPlayback
Not supported
MultiCAN-500 PDCBtnFCIM
Not supported
MultiCAN-501 CDiffType
Not supported
MultiCAN-501 FntOptDiskDrive
No ODD
MultiCAN-502 EDTType
Brink MXe HD
MultiCAN-502 FuelPumpType
Gasoline FPDM
MultiCAN-503 IntelCruiseCtrl
Not supported
MultiCAN-503 ConnectInfoStatus
CI Framework Active
MultiCAN-503 ExternalConnectivity
Undefined 4
MultiCAN-504 TrailerTPMS
Not supported
MultiCAN-504 NoseLoadMeasure
Not Fitted
MultiCAN-504 TrailerLightMod
Fitted
MultiCAN-504 ElecDepTowBar
Not Fitted
MultiCAN-505 WalkAwayLocking
Not Enabled
MultiCAN-505 DepSideSteps
Not Fitted
MultiCAN-505 TowingAero
Not supported
MultiCAN-505 ElecTrailerPDC
Fitted
MultiCAN-506 ClusterAlertGFX
Generic Warning Display
MultiCAN-506 RestrictSunroofOpen
Unrestricted
MultiCAN-506 KeyFobTechnology
Mechanical Key Blade
MultiCAN-507 RearExitDetect
Not supported
MultiCAN-507 DualViewBtnFCIM
Not supported
MultiCAN-507 CameraBtnFCIM
Not supported
MultiCAN-507 PedProtectSystem
Not Fitted
MultiCAN-508 PassDoorLock
Lock Only
MultiCAN-508 AutoAccessHeight
Not supported
MultiCAN-508 DriverDoorLock
Lock & Unlock Only
MultiCAN-509 RRPassDoorLock
No Switch Fitted
MultiCAN-509 RLPassDoorLock
No Switch Fitted
MultiCAN-509 ECOmodeText
Not supported
MultiCAN-510 VehicleLocator
Enabled
MultiCAN-510 SoftCloseDoors
Not Fitted
MultiCAN-510 AirIonizer
Front Air Ionizer fitted
MultiCAN-511 TelUnlock
Enabled
MultiCAN-511 SunGblClTelLock
Not supported
MultiCAN-511 WinGblClTelLock
Disabled
MultiCAN-511 TelLock
Enabled
MultiCAN-512 PwrTailKickSen
Power tailgate with Kick Sensing not fitted
MultiCAN-512 PwrTailProxSenPEPS
Power tailgate with Proximity Sensing not fitted
MultiCAN-512 TelAlarmReset
Enabled
MultiCAN-512 VASSensorOvride
Enabled
MultiCAN-513 2ndRowLoadSpace
Not Fitted
MultiCAN-513 PassDoorLockLED
Global
MultiCAN-513 DriverDoorLockLED
Global
MultiCAN-514 StopStartInhibitIcon
Stop Start Inhibited Icon enabled (CFSS)
MultiCAN-514 RRPassDoorLockLED
Not Fitted
MultiCAN-514 RLPassDoorLockLED
Not Fitted
MultiCAN-515 HeightDataInputSelection
Height via Analogue Height sensors
MultiCAN-515 FntLowBeamProfile
Diagnostic Profile 12
MultiCAN-516 HUDNavigation
Not supported
MultiCAN-516 RearStopProfile
MultiCAN-517 ActiveVanes
ActiveVanes fitted (upper OR lower OR both)
MultiCAN-517 RearPosProfile
Diagnostic Profile 5
MultiCAN-518 ArmouredVehicle
Standard
MultiCAN-518 RearSMProfile
MultiCAN-519 BMSColdClimateMode
Not Fitted
MultiCAN-519 NumberPlateProfile
MultiCAN-520 BrakeSystemTypeTVB
Fitted
MultiCAN-520 RearFogProfile
MultiCAN-521 BrakeSystemTypeSCS
Not supported
MultiCAN-521 RearReverseProfile
MultiCAN-522 BrakeSystemTypeDSC
Not Fitted
MultiCAN-522 RearDIProfile
Diagnostic Profile 4
MultiCAN-523 CentreDiffLock
Fitted
MultiCAN-523 FntHighBeamProfile
MultiCAN-524 2CAS
Not Fitted
MultiCAN-524 CornerLampProfile
MultiCAN-525 ARC
Not Fitted
MultiCAN-525 NumplateFdbkMech
MultiCAN-525 CHMSLFdbkMech
MultiCAN-526 SAS
Fitted
MultiCAN-526 NumplateDrvMech
Driven via BCM
MultiCAN-526 CHMSLDrvMech
Driven via BCM
MultiCAN-527 PolePairsRearOnly
48 Pole Pairs
MultiCAN-527 PolePairsFntOnly
48 Pole Pairs
MultiCAN-528 2CAL
Not Fitted
MultiCAN-528 ActiveExhaust
System not fitted
MultiCAN-528 RideHeight
Not supported
MultiCAN-529 CoilCoil
Not Fitted
MultiCAN-529 ColmnDwnExtProfile
Not supported
MultiCAN-530 GearShiftIndicator
Fitted
MultiCAN-530 ColmnExtProfile
Not supported
MultiCAN-531 DieselSoundQuality
Fitted
MultiCAN-531 ColmnRetractProfile
Not supported
MultiCAN-532 WheelBase
Standard
MultiCAN-532 ColmnUpRetractProfile
Not supported
MultiCAN-533 CVD
Fitted
MultiCAN-533 LampSupplyLeftProfile
MultiCAN-534 LimitedSlipDiff
Not supported
MultiCAN-534 LampSupplyRightProfile
MultiCAN-535 RrDiffLockEDiff
Fitted
MultiCAN-535 HeatWasherProfile
Not supported
MultiCAN-536 GearboxPaddlesInDrive
Disabled in Drive
MultiCAN-536 ParkAidECUProfile
Not supported
MultiCAN-537 SWSGearSelectors
Not Fitted
MultiCAN-537 Ignition1Profile
Not supported
MultiCAN-538 OilLevelWarning
Enabled
MultiCAN-538 Ignition2Profile
Not supported
MultiCAN-539 CMbBFitment
Not Fitted
MultiCAN-539 Ignition3Profile
Not supported
MultiCAN-540 TOJDO
Fitted
MultiCAN-540 Ignition4Profile
Not supported
MultiCAN-541 4CAS
Fitted
MultiCAN-541 Ignition5Profile
Not supported
MultiCAN-542 eCallgasTank
Fitted
MultiCAN-542 Ignition6Profile
Not supported
MultiCAN-543 eCalldieselTank
Not Fitted
MultiCAN-543 Ignition7Profile
Not supported
MultiCAN-544 eCallcompNaturalGas
Not Fitted
MultiCAN-544 Ignition8Profile
Not supported
MultiCAN-545 eCallliquidPropaneGas
Not Fitted
MultiCAN-545 Ignition9Profile
Not supported
MultiCAN-546 eCallelecEnergyStorage
Not Fitted
MultiCAN-546 ColmnExtOpenLoad
Not supported
MultiCAN-546 ColmnDwnExtOpenLoad
Not supported
MultiCAN-547 eCallhydrogenStorage
Not Fitted
MultiCAN-547 ColmnUpRetractOpenLoad
Not supported
MultiCAN-547 ColmnRetractOpenLoad
Not supported
MultiCAN-548 eCallotherPropStorage
Not Fitted
MultiCAN-548 LampSupplyRightOpenLoad
No OL
MultiCAN-548 LampSupplyLeftOpenLoad
No OL
MultiCAN-549 IMCFanAssyAuxCooling
Not Fitted
MultiCAN-549 ParkAidECUOpenLoad
Not supported
MultiCAN-549 HeatWasherOpenLoad
Not supported
MultiCAN-550 EcoModeButtonFit
Fitted
MultiCAN-550 Ignition2OpenLoad
Not supported
MultiCAN-550 Ignition1OpenLoad
Not supported
MultiCAN-551 EasyEntExtSetMenu
Disabled
MultiCAN-551 Ignition4OpenLoad
Not supported
MultiCAN-551 Ignition3OpenLoad
Not supported
MultiCAN-552 ScnSurrSwtchs
Not supported
MultiCAN-552 Ignition6OpenLoad
Not supported
MultiCAN-552 Ignition5OpenLoad
Not supported
MultiCAN-553 ComfortPlus
Comfort Plus Fitted
MultiCAN-553 Ignition8OpenLoad
Not supported
MultiCAN-553 Ignition7OpenLoad
Not supported
MultiCAN-554 HSTDervative
Not supported
MultiCAN-554 AutoRangeChange
Not supported
MultiCAN-554 Ignition9OpenLoad
Not supported
MultiCAN-555 TrailerTestItem2
LH direction indicator
MultiCAN-555 TrailerTestItem1
All lights on
MultiCAN-556 TrailerTestItem4
RH direction indicator
MultiCAN-556 TrailerTestItem3
Brake light
MultiCAN-557 TrailerTestItem6
Reverse light
MultiCAN-557 TrailerTestItem5
Both position lights
MultiCAN-558 TrailerTestItem8
Sequence complete
MultiCAN-558 TrailerTestItem7
Fog light
MultiCAN-559 TrailerTestItem10
Sequence complete
MultiCAN-559 TrailerTestItem9
Sequence complete
MultiCAN-560 DrLtchStatusFdbk
ALL Doors have a Physical Latch Status Feedback
MultiCAN-560 MudRutMode
Available for selection with timeout
MultiCAN-560 GGSWinterMode
MultiCAN-561 PartialNetworkEnable
Partial Networking Enabled
MultiCAN-561 RockCrawlMode
MultiCAN-561 SandProgMode
MultiCAN-562 SideWinGlassThick
Not supported
MultiCAN-562 ECOProgMode
MultiCAN-562 DynamicProgMode
Not available for selection
MultiCAN-563 AlrmSensOnSingLock
No Alarm Sensors on Single Lock
MultiCAN-563 USB3Repeater
Not Fitted
MultiCAN-563 USB2Hub
Not Fitted
MultiCAN-564 MaxVehicleSpeed
LIMIT_191_KPH
MultiCAN-565 LockFuelFillFlap
Not Fitted
MultiCAN-565 FntPosOpenLoad
No OL
MultiCAN-565 FntSMOpenLoad
No OL
MultiCAN-566 MHLastUserMode
Last user memory mode disabled
MultiCAN-566 FntLowBeamOpenLoad
No OL
MultiCAN-566 FntDRLOpenLoad
No OL
MultiCAN-567 BodyStyleRoofStructure
fixed
MultiCAN-567 RearPosOpenLoad
No OL
MultiCAN-567 FntFogOpenLoad
OL in ON state
MultiCAN-568 BattStatChargeGauge
Not supported
MultiCAN-568 RearFogOpenLoad
No OL
MultiCAN-568 RearReverseOpenLoad
OL in ON state
MultiCAN-569 AVES
AVES not fitted
MultiCAN-569 CHMSLOpenLoad
No OL
MultiCAN-569 FrontCornerLampOpenLoad
No OL
MultiCAN-570 ConvenienceFold
Not Fitted
MultiCAN-570 RearDIOpenLoad
No OL
MultiCAN-570 NumberPlateOpenLoad
No OL
MultiCAN-571 VehDimTouch
Enabled
MultiCAN-571 RearSMOpenLoad
No OL
MultiCAN-571 RearStopOpenLoad
OL in ON state
MultiCAN-572 DiesAfterSysUREASCR
Disabled
MultiCAN-572 FntDIOpenLoad
No OL
MultiCAN-572 FntHighBeamOpenLoad
No OL
MultiCAN-573 OilPressureWarn
Disabled
MultiCAN-573 SteeringAngleSensor
Not supported
MultiCAN-573 OilLevelTopUpRes
1.0 litre
MultiCAN-574 OilLevelTopUpValue
1.0 litre
MultiCAN-575 EDiffType
EDiff Type 1
MultiCAN-575 SpdoCalkmhOffset
+ 0.0 km/h
MultiCAN-576 RearPassMemDrSwtchPk
Not Fitted
MultiCAN-576 RearDriverMemDrSwtchPk
Not Fitted
MultiCAN-576 PassMemDrSwtchPk
Not Fitted
MultiCAN-576 DriverMemDrSwtchPk
Not Fitted
MultiCAN-577 CoolingFanFitment
Single Electric fan/controller fitted
MultiCAN-577 SpdoCalPercentScale
2.0% Scaling
MultiCAN-578 LRTerrainJGAllRdLaunch
Enabled
MultiCAN-578 SplitStopFailStrat
Not supported
MultiCAN-578 SteerWlhlSwtchType
SWS Dual LIN & AmbientLight (default)
MultiCAN-579 HdlampLvlSensPos
Left side height sensors
MultiCAN-579 AutoAccess
Feature available with driver configuration via IMC
MultiCAN-579 TowAssist
Tow Assist 2
MultiCAN-580 PTCruiseFitment
Normal cruise fitted
MultiCAN-580 GenericEngPwrOut
Standard high power engine variant
MultiCAN-581 TPMSCalibration
Undefined 3
MultiCAN-582 FinalDriveRatioComp (MSB)
4.10 FDR / 4.30 FDR
MultiCAN-583 FinalDriveRatioComp (LSB)
4.10 FDR
MultiCAN-584 NextGenPwrTrnSQ
PTSQ NLI
MultiCAN-585 ActSndDesignPwrlvl
NGPTSQ
MultiCAN-586 PanoramicRoof
Fitted
MultiCAN-586 DoorBodyStyle
5 Door / 4 Door estate body style
MultiCAN-586 DrivenWheels
All Wheel Drive (permanently connected)
MultiCAN-587 PetrolEMSEmissMkt
Federal
MultiCAN-588 NextGenPwrTrnSQCalNo
Calibration 1
MultiCAN-589 RearPassLinSWP
Not supported
MultiCAN-589 RearDriverLinSWP
Not supported
MultiCAN-590 BrakeDiscSizeRear
18 inch
MultiCAN-590 BrakeDiscSizeFront
18 inch
MultiCAN-591 Sportbrake
Standard
MultiCAN-591 ElectricFan
Single
MultiCAN-591 BrakeDiscMaterial
Iron
MultiCAN-592 ServiceIntervalMSB
Undefined 132
MultiCAN-593 ServiceIntervalLSB
Undefined 208
MultiCAN-594 TyreDynamicRollRadMSB
2325mm (D8, L551) / 2387mm (L405, L462, L494)
MultiCAN-595 TyreDynamicRollRadLSB
Undefined 167
MultiCAN-596 TyreSizeCorrnFac
235/50
MultiCAN-597 TyreSizeCorrnFac
255/70 R18 A/T
MultiCAN-598 EnginePowerOutput
MSB
MultiCAN-599 EnginePowerOutput
Engine Power Source - 300/700
MultiCAN-600 FuelTimeToServiceMSB
Undefined 2
MultiCAN-601 FuelTimeToServiceLSB
Undefined 218
MultiCAN-602 HybridType
Auto Transmission Stop/Start
MultiCAN-602 PDC
PDC not fitted
MultiCAN-603 ChassisDescription
No sub-variant
MultiCAN-603 GearboxDescription
8 Speed Auto (8HP45)
MultiCAN-604 PTAODieWaterInSensr
Not Fitted
MultiCAN-604 TransmissionSelectr
Undefined 40
MultiCAN-604 BrakeWarningSymbol
text
MultiCAN-605 GenericWheelBase
Standard
MultiCAN-605 ReverseGearSelStrat
Reverse Gear Selection Strategy Disabled
MultiCAN-605 ConfigDynamicMode
Not Fitted
MultiCAN-623 FntClusterCableLgth
2 - 2.9m
MultiCAN-623 FntDispCableLgth
2 - 2.9m
MultiCAN-624 RearLftDispCableLgth
Not Fitted
MultiCAN-624 FntUIPCableLgth
Not supported
MultiCAN-625 RearUIPLnk1CableLgth
Not Fitted
MultiCAN-625 RearRghtDisplayCableLgth
Not Fitted
MultiCAN-626 AllSurfaceInfo
Not Fitted
MultiCAN-626 RrLmpBhWhTgateOpen
TrunkStatusOutput Disabled
MultiCAN-626 RearUIPLnk2CableLgth
Not Fitted
MultiCAN-627 SeatPSASWFitted
Not supported
MultiCAN-627 DriverWinSWPack
Rear Window Lock Out Switch
MultiCAN-627 BrowserSearch
MultiCAN-628 SeatMasgSWFittedRP
Not Fitted
MultiCAN-628 SeatMasgSWFittedRD
Not Fitted
MultiCAN-628 SeatMasgSWFittedP
Not Fitted
MultiCAN-628 SeatMasgSWFittedD
Not Fitted
MultiCAN-629 SeatLumbSWFittedRP
Not Fitted
MultiCAN-629 SeatLumbSWFittedRD
Not Fitted
MultiCAN-629 SeatLumbSWFittedP
Not Fitted
MultiCAN-629 SeatLumbSWFittedD
Not Fitted
MultiCAN-630 SeatMovSWFittedRP
Not supported
MultiCAN-630 SeatMovSWFittedRD
Not supported
MultiCAN-630 SeatMovSWFittedP
Not supported
MultiCAN-630 SeatMovSWFittedD
Not supported
MultiCAN-631 PNChargingFunction
Enabled
MultiCAN-631 SpareWheelCarrier
JLR Integrated SWC
MultiCAN-631 GrillActiveVanes
Upper and Lower Grill Active Vanes fitted
MultiCAN-632 ViscousFan
Not Fitted
MultiCAN-632 HeatedWasherJets
Fitted
MultiCAN-632 AutoBlindEnabled
EnabledWithUserOverride
MultiCAN-633 AquaBladeWashDir
Wash upstroke
MultiCAN-633 AquaBladeFitted
Fitted
MultiCAN-633 AutolightSensorFit
Fitted
MultiCAN-633 WiperMotorModule
Smart wiper motor
MultiCAN-634 MovingWindows
Four Moving Windows
MultiCAN-634 CDiffBknHalfShfDet
Not supported
MultiCAN-634 PNFuelRefill
Not supported
MultiCAN-635 CDiffRangeChgType
Not supported
MultiCAN-635 Towing
Not supported
MultiCAN-635 BodyStyleSeatLayout
5-seat style (2 row)
MultiCAN-636 RearAnimatedIndicator
Not Fitted
MultiCAN-636 FntAnimatedIndicator
Not Fitted
MultiCAN-636 AdaptDrvBeam
AdaptDrvBeam Disabled
MultiCAN-636 LaserHighBeam
Laser High Beam Disabled
MultiCAN-637 DriverIDCamera
Not supported
MultiCAN-637 GestureBlindFront
Disabled
MultiCAN-637 HeightInputSelection
Height via CAN
MultiCAN-638 DriverIDKeys
Fitted
MultiCAN-638 FrontPassengerID
Not supported
Automatic
MultiCAN-639 DriverIDPhones
Fitted
MultiCAN-639 Personalisation
Not Fitted
MultiCAN-639 Row2PassengerID
Not supported
MultiCAN-640 EcoDataGallonType
US Gallons
MultiCAN-640 DriverIDSeats
Not supported
MultiCAN-640 Row3PassengerID
Not supported
MultiCAN-641 FrntUpperDispVariant
Panasonic 10 Inch Single View
MultiCAN-641 FrntLowerDispVariant
Not Fitted
MultiCAN-642 TransCalibrationIndex
Calibration Index #1
MultiCAN-642 FrntUpperDeployable
Not Fitted
MultiCAN-642 FrntLowerDispKeys
Not supported
MultiCAN-643 NGICamBanStrat
Not supported
MultiCAN-643 NonDepIllumDoorHnd
Not supported
MultiCAN-643 DieselEMSEmissMkt
Fedral
MultiCAN-644 SmartExitRrPassDoor
Fitted
MultiCAN-644 SmartExitRrDrvDoor
Fitted
MultiCAN-644 SmartExitFntPassDoor
Fitted
MultiCAN-644 SmartExitFntDrvDr
Fitted
MultiCAN-645 FntPassWdowSwtchpk
Hardwired
MultiCAN-645 FrntDrvWdowSwtchpk
Non Capacitive switchpack
MultiCAN-646 RrPassWdowSwtchpk
Hardwired
MultiCAN-646 RrDrvWdowSwtchpk
Hardwired
MultiCAN-647 ChargingInlet2
Inlet Not Fitted
MultiCAN-647 ChargingInlet1
Inlet Not Fitted
MultiCAN-648 TelematicsSpkrType
TELEMATICS_MID_RANGE
MultiCAN-648 MicrophoneType
Microphone Type 1
MultiCAN-649 EMMaxDurEngOff
Not supported
MultiCAN-650 FMMaxFuelAge
Not supported
MultiCAN-651 SelectStateCharge
Not Fitted
MultiCAN-651 WirelessCharger
Not supported
MultiCAN-651 TimedChrgFeature
Timed Charging not fitted
MultiCAN-652 ParkAidCommsBus
Not Supported
MultiCAN-652 ReverseMirrorDipStrat
Not enabled
Not enabled
MultiCAN-653 OpenableICP
Not Fitted
MultiCAN-653 RearRoofBlindFitted
Not Fitted
MultiCAN-653 SeatThermHMIControl
Display 1st & 2nd Row Seat Thermal Pages in Touchscreen (not 3rd)
MultiCAN-654 BrakePedalFeel
Brake Pedal Feel 1
MultiCAN-655 IMCClusterAPIXVideoSpd
3 Gigabits/second
MultiCAN-655 IMCClusterAPIXClrDpth
24 bit
MultiCAN-656 FarSideOccImpAbgRow1
Not supported
MultiCAN-656 CntrRetractPretRow3
Not supported
MultiCAN-656 CntrRetractPretRow2
Not supported
MultiCAN-656 CntrRetractPretRow1
Not supported
MultiCAN-657 CleanSurroundCams
No Clean Camera
MultiCAN-657 AuxCoolingPump
AuxCoolingPump Fitted (PCM controlled)
MultiCAN-657 PNPreConEnable
Not supported
MultiCAN-658 ParkAssistHMI
Low Line HMI
MultiCAN-658 GrndMarkingDetect
Not Avaliable
MultiCAN-658 RoofType
Fixed Roof
MultiCAN-659 OverrunConfig
Not Fitted
MultiCAN-659 ClimateSyncHardKey
Climate Synchronisation Hard Key NOT fitted
MultiCAN-659 LSAEB
Not Avaliable
MultiCAN-660 DisplayTemperature
Display Rear Temperature value(s) in Touchscreen.
MultiCAN-660 RDUType
Undefined 24
MultiCAN-660 ActivityKey
Not Fitted
MultiCAN-661 NGISubscriptionVerMSB
Undefined 4
MultiCAN-662 NGISubscriptionVerLSB
Undefined 12
MultiCAN-663 IMCAPIXVideoSettings
Error
MultiCAN-664 LHSWSFavourite
Fitted
MultiCAN-664 LHSWSPhoneState
Fitted
MultiCAN-664 AutoVents
Auto Vents not fitted
MultiCAN-664 DPFDesulphurisation
DeSox Not Fitted
MultiCAN-665 ChauffeurMode
Not Fitted
MultiCAN-665 IntDigitalMirror
Fitted with cleaning system
MultiCAN-665 AdjustTemperature
Display Rear Temperature adjust button(s) in Touchscreen.
MultiCAN-666 CPillarSwitch
Not Fitted
MultiCAN-666 HUDSubType
HUD Not Fitted
MultiCAN-666 DepDoorHandType
Not supported
MultiCAN-667 IntelligentSeatFold
Not fitted
MultiCAN-668 TipandSlideSwitch
Not Fitted
MultiCAN-668 HybridModeSelect
Not enabled
MultiCAN-668 SpoilerType
No Spoiler fitted
MultiCAN-669 iBBMInstalled
Not supported
MultiCAN-669 AutoTRHostECU
CHCM
MultiCAN-669 WirelessChargingAlign
Not Fitted
MultiCAN-670 FwdTrafficDetection
Not supported
MultiCAN-670 SlcTimedClimate
Not Fitted
MultiCAN-670 DisplayDistribution
Display Front+Rear Climate Distribution button(s) in Touchscreen.
MultiCAN-671 SeeThroughBonnet
With See Through Bonnet
MultiCAN-671 SlcClimateSeats
Not Fitted
MultiCAN-671 SlcCabinTemp
Not Fitted
MultiCAN-672 TJAICA
Not Fitted
MultiCAN-672 SlcHeatedSteerWhl
Not Fitted
MultiCAN-672 SlcMassageSeats
Not Fitted
MultiCAN-673 TRUserInputMethod
Input Method 2
MultiCAN-673 SlcDeviceReminder
Not Fitted
MultiCAN-673 SlcMediaSource
Not Fitted
MultiCAN-674 AFS123
AFS123 Disabled
MultiCAN-674 EMSMktCal
Not Supported
MultiCAN-674 SlcCallList
Not Fitted
MultiCAN-675 ActiveExhaustButtonType
Not Fitted
MultiCAN-675 BrakePadTypeRear
Not supported
MultiCAN-676 SurroundMode
Without Surround Audio
MultiCAN-676 BrakePadTypeFront
Not supported
MultiCAN-677 MildHybridType
MHEV System NOT implemented
MultiCAN-677 ElectricDrivePower
Not Supported
MultiCAN-678 HitchAssistTowbar
5 Seat NAS Towbar
MultiCAN-679 HeadlightsVariant
Headlamp_Variant_Mid_C
MultiCAN-680 TaskLighting
Not Fitted
MultiCAN-680 ClearExitDetectionSystem
Fitted
MultiCAN-680 BodyKitStyle
Core body kit
MultiCAN-681 BacklightStratSel
BacklightLinearControlStrategy (No Night/Day Switching)
MultiCAN-681 DriveAssist
Drive Assist Avaliable
MultiCAN-681 SuspensionType
4 Corner Air
MultiCAN-682 DynamicLiteMode
MultiCAN-682 SeatTherm2ndRowHMIControl
Display 2nd row Seat Thermal page
MultiCAN-682 SAPServerType
Not supported
MultiCAN-683 IntelEmrgBrkingCAEB
Not supported
MultiCAN-683 EngineNoiseCancel
Not Supported
MultiCAN-683 ChrgePrtFlpInhibit
Fitted
MultiCAN-683 Front23BuckSwitch
2 Seats in Row 1
MultiCAN-684 Row3BuckleSwitch
Not Supported
MultiCAN-684 HtdFntCntreArmrst
Not Fitted
MultiCAN-684 HeatedDoorArmrest
Not Fitted
MultiCAN-685 Unallocated
Undefined 32
MultiCAN-685 HeatedCalfRest
Not Fitted
MultiCAN-685 HtdRearCntreArmrst
Not Fitted
MultiCAN-686 LowerGloveBox
Manual
MultiCAN-686 UpperGloveBox
Not Fitted
MultiCAN-686 HeatedMapPocket
Not Fitted
MultiCAN-687 UWBSATFreqChannel
Undefined 6
MultiCAN-688 Exhaust Type
SINGLE SIDED
MultiCAN-688 Seat Msg 2nd Row HMI Control
Do not display 2nd row Seat Massage page
MultiCAN-688 MirrorPositionFeature
Estimated Folded/Unfolded
MultiCAN-690 Seat Msg HMI Control
Display All Row Seat Massage Pages in Touchscreen
MultiCAN-695 GearRatioSpread
7.1 Gear Ratio Spread
MultiCAN-698 RH SWS Bus Selection
Not supported
MultiCAN-698 Climate Zonal Control
Not Fitted
MultiCAN-698 Chg Port Flp Inhibit
Not supported
MultiCAN-698 ATCM EV Switch
ATCM Electric Vehicle Switch not fitted or Blade d
MultiCAN-700 UWB PEPS END IS ONLY USE VSA
UWB PEPS Enabled
MultiCAN-705 DEPLOYABLE SIDE STEP TYPE
Type 4 (355 Hall counts) on TBM
MultiCAN-706 Sign Post Dimming
Not Fitted
MultiCAN-724 ChargeFlap2
Not Fitted
MultiCAN-724 ChargeFlap1
Not Fitted
MultiCAN-725 Wiper Rear Continue
Disabled
MultiCAN-725 Wiper Inter Spd Depend
Enabled
MultiCAN-726 Wiper Up Stroke Feature
Disabled
MultiCAN-726 Wiper Drip Wipe Feature
Enabled
MultiCAN-726 Wiper Fnt Speed Depend
Enabled
MultiCAN-727 Winter Wiper Park
Not supported
MultiCAN-728 Headlamp Wash
Fitted
MultiCAN-728 Autolamp Fast Response
Disabled
MultiCAN-728 Wiper Rr Hlf Moon Park Swtch
Disabled
MultiCAN-728 Wiper Hdlmp Wsh Pressure
Low
MultiCAN-729 Sunroof Type
Opening Glass
MultiCAN-729 Wiper Winter Park
Enabled
MultiCAN-729 RC Drive
Not Fitted
MultiCAN-736 Column Adjust Type
Manual Column
MultiCAN-740 Auto Relock
Disabled
MultiCAN-740 Alarm Passive Arming
Enabled
MultiCAN-741 Alarm Arm Disarm Chirp
Disabled
MultiCAN-743 Double Locking Chirp
Disabled
MultiCAN-745 Tailgate Remote Release
Not Supported
MultiCAN-752 TR Fitment
Fitted
MultiCAN-752 Enhanced Filtration
Enhanced Particulate Filter and soft button fitted
MultiCAN-752 NFS Variant
NFS Mid
MultiCAN-754 ULPM Prog Mode
MultiCAN-766 PSDB Fitted
Not Supported
MultiCAN-769 Battery1 Type
Undefined 20
MultiCAN-772 Trip Comp Initial Units
Imperial / US
MultiCAN-772 Speedo Second Display
Displayed
MultiCAN-772 Speedo Main Scale Units
Menu
MultiCAN-773 IVIType
PIVI Mid Line
MultiCAN-781 Pre Crash Seat Squab
Not supported
MultiCAN-781 Odometer Units
same as trip computer
MultiCAN-781 Spdo Second Display Unit
MPH
MultiCAN-785 Battery2 Type
Not Fitted
MultiCAN-787 VI Auto Start
Enabled
MultiCAN-787 Speedo Minor Scale
Not Displayed
MultiCAN-787 Spdo Scnd Disp Enbl Menu
Enabled
MultiCAN-787 BSCM Fitted
Not Fitted
MultiCAN-792 DADC Module
DADC LL
MultiCAN-792 Telematics Sign In
Sign-in not possible
MultiCAN-792 Hands On Detection
Not Fitted
MultiCAN-793 CCM Variant
MRRevo14F Fitted
MultiCAN-793 TA2 Input Control
BLADE rotary
MultiCAN-794 Rear Corner Radars
Rear corner radars fitted
MultiCAN-814 IVIWiFiHotspot
Internal WiFi Hotspot fitted
MultiCAN-835 Special Vehicles
Not a Special Vehicle
MultiCAN-835 Rr Climate Seats SZM
No Heated or Climate Seats
MultiCAN-845 TR Input HMI
Shared Rotary & Driver Mode Button & Touchscreen
MultiCAN-845 TR Icon Strategy
Off Unavailable Available Active MCIP Presel
Not supported
Not supported
Not supported
Not supported
Not supported
No ODD
Brink MXe HD
Gasoline FPDM
Not supported
CI Framework Active
Undefined 4
Not supported
Not Fitted
Fitted
Not Fitted
Not Enabled
Not Fitted
Not supported
Fitted
Unrestricted
Not supported
Not supported
Not supported
Not Fitted
Lock Only
Not supported
Lock & Unlock Only
No Switch Fitted
No Switch Fitted
Not supported
Enabled
Not Fitted
Enabled
Not supported
Disabled
Enabled
Enabled
Enabled
Not Fitted
Global
Global
Not Fitted
Not Fitted
Not supported
Standard
Not Fitted
Fitted
Not supported
Not Fitted
Fitted
MultiCAN-524 2CAS
Not Fitted
MultiCAN-525 ARC
Not Fitted
MultiCAN-526 SAS
Fitted
Driven via BCM
Driven via BCM
48 Pole Pairs
48 Pole Pairs
MultiCAN-528 2CAL
Not Fitted
System not fitted
Not supported
Not Fitted
Not supported
Fitted
Not supported
Fitted
Not supported
Standard
Not supported
MultiCAN-533 CVD
Fitted
Not supported
Fitted
Not supported
Disabled in Drive
Not supported
Not Fitted
Not supported
Enabled
Not supported
Not Fitted
Not supported
MultiCAN-540 TOJDO
Fitted
Not supported
MultiCAN-541 4CAS
Fitted
Not supported
Fitted
Not supported
Not Fitted
Not supported
Not Fitted
Not supported
Not Fitted
Not supported
Not Fitted
Not supported
Not supported
Not Fitted
Not supported
Not supported
Not Fitted
No OL
No OL
Not Fitted
Not supported
Not supported
Fitted
Not supported
Not supported
Disabled
Not supported
Not supported
Not supported
Not supported
Not supported
Comfort Plus Fitted
Not supported
Not supported
Not supported
Not supported
Not supported
All lights on
Brake light
Reverse light
Sequence complete
Fog light
Sequence complete
Sequence complete
Not supported
Not Fitted
Not Fitted
LIMIT_191_KPH
Not Fitted
No OL
No OL
No OL
No OL
fixed
No OL
OL in ON state
Not supported
No OL
OL in ON state
MultiCAN-569 AVES
AVES not fitted
No OL
No OL
Not Fitted
No OL
No OL
Enabled
No OL
OL in ON state
Disabled
No OL
No OL
Disabled
Not supported
1.0 litre
1.0 litre
EDiff Type 1
+ 0.0 km/h
Not Fitted
Not Fitted
Not Fitted
Not Fitted
2.0% Scaling
Enabled
Not supported
Tow Assist 2
Undefined 3
4.10 FDR / 4.30 FDR
4.10 FDR
PTSQ NLI
NGPTSQ
Fitted
Federal
Calibration 1
Not supported
Not supported
18 inch
18 inch
Standard
Single
Iron
Undefined 132
Undefined 208
Undefined 167
235/50
255/70 R18 A/T
MSB
Undefined 2
Undefined 218
MultiCAN-602 PDC
PDC not fitted
No sub-variant
Not Fitted
Undefined 40
text
Standard
Not Fitted
2 - 2.9m
2 - 2.9m
Not Fitted
Not supported
Not Fitted
Not Fitted
Not Fitted
Not Fitted
Not supported
Not Fitted
Not Fitted
Not Fitted
Not Fitted
Not Fitted
Not Fitted
Not Fitted
Not Fitted
Not supported
Not supported
Not supported
Not supported
Enabled
JLR Integrated SWC
Not Fitted
Fitted
Wash upstroke
Fitted
Fitted
Smart wiper motor
Four Moving Windows
Not supported
Not supported
Not supported
MultiCAN-635 Towing
Not supported
Not Fitted
Not Fitted
Not supported
Disabled
Height via CAN
Fitted
Not supported
Automatic
Fitted
Not Fitted
Not supported
US Gallons
Not supported
Not supported
Not Fitted
Not Fitted
Not supported
Not supported
Not supported
Fedral
Fitted
Fitted
Fitted
Fitted
Hardwired
Hardwired
Hardwired
Inlet Not Fitted
Inlet Not Fitted
Microphone Type 1
Not supported
Not supported
Not Fitted
Not supported
Not Supported
Not enabled
Not enabled
Not Fitted
Not Fitted
Brake Pedal Feel 1
3 Gigabits/second
24 bit
Not supported
Not supported
Not supported
Not supported
No Clean Camera
Not supported
Low Line HMI
Not Avaliable
Fixed Roof
Not Fitted
MultiCAN-659 LSAEB
Not Avaliable
Undefined 24
Not Fitted
Undefined 4
Undefined 12
Error
Fitted
Fitted
DeSox Not Fitted
Not Fitted
Not Fitted
HUD Not Fitted
Not supported
Not fitted
Not Fitted
Not enabled
No Spoiler fitted
Not supported
CHCM
Not Fitted
Not supported
Not Fitted
Not Fitted
Not Fitted
MultiCAN-672 TJAICA
Not Fitted
Not Fitted
Not Fitted
Input Method 2
Not Fitted
Not Fitted
MultiCAN-674 AFS123
AFS123 Disabled
Not Supported
Not Fitted
Not Fitted
Not supported
Not supported
Not Supported
5 Seat NAS Towbar
Not Fitted
Fitted
Core body kit
4 Corner Air
Not supported
Not supported
Not Supported
Fitted
2 Seats in Row 1
Not Supported
Not Fitted
Not Fitted
Undefined 32
Not Fitted
Not Fitted
Manual
Not Fitted
Not Fitted
Undefined 6
SINGLE SIDED
Not supported
Not Fitted
Not supported
UWB PEPS Enabled
Not Fitted
Not Fitted
Not Fitted
Disabled
Enabled
Disabled
Enabled
Enabled
Not supported
Fitted
Disabled
Disabled
Low
Opening Glass
Enabled
Not Fitted
Manual Column
Disabled
Enabled
Disabled
Disabled
Not Supported
Fitted
NFS Mid
Not Supported
Undefined 20
Imperial / US
Displayed
Menu
PIVI Mid Line
Not supported
MPH
Not Fitted
Enabled
Not Displayed
Enabled
Not Fitted
DADC LL
Not Fitted
MRRevo14F Fitted
BLADE rotary
