Headlight LED Halo out - LED indicator surround oddifies
I have experienced my first Defender part failure since I got in (so almost five years - not too shabby!). Initially it seemed strightforward - the driver side LED halo is out, passenger one works fine - easy enough. However, I noticed something odd - say I unlock the doors - passenger halo lights, drivers does not, and both sides have the indicator surrounds come on. That seems fine, but then the driver side LED indicator surrounds go out after about 5-10 seconds while the passenger side all stays lit. Is this something more than just failure of the LED driver for the halo? Is it still related? Or do I need an entirely different set of parts? I've been trying to riddle this out though searches to make sure I'm getting the right thing, but I'm getting a little confused. Headlight itself still works just fine (and auto-levels). I assumed the indicator surrounds are a separate thing, so now I'm thinking it's more complicated since both sides aren't acting the same.
Thanks for any / all help that can be provided!
This is exactly what happens when the halo is dead.
nothing else is wrong.
the two white squares light up for a short time after turning on before going dark
New LED module or swap the headlight and all is well.
$3 or $380
tricky or simple
A couple of hours DIY or 30 mins.
$3 or $380
tricky or simple
$3 or $380
tricky or simple
$3 or $380
tricky or simple
Thank you!
$3 or $380
tricky or simple
$3 or $380
tricky or simple
Where can I get a headlight for $380?
Aliexpress, ebay are the two best options. I paid $2.38 shipped. There are tons of options there.
