"Headlights Fault Detected" after new Headlamp install
Old Aug 22, 2025 | 03:24 PM
KamboMD's Avatar
Default "Headlights Fault Detected" after new Headlamp install
Hey guys,
So first off, I replaced my passenger's headlight after having the day light running lights stop working. I bought a brand new one off Ebay for $500, and took about 20 minutes to replace it. Mechanic wanted $1200 to install even if I supplied the part, which is wild. But...maybe I'm thinking I did something wrong. The new headlamp works completely as if brand new, but shortly after having the car run I am getting a "Headlights Fault Detected" but everything is working just fine. Unplugged my battery for 30 minutes too and still pops up.
Any insight is greatly appreciated.
Old Aug 22, 2025 | 04:55 PM
wcc18999's Avatar
I think -not sure- that the new headlight needs to be coded to the car.
Old Aug 22, 2025 | 04:57 PM
wcc18999's Avatar
From ChatGPT:
  • Halogen headlights → No coding required. These are more basic and typically plug-and-play.
  • LED / Matrix LED headlights (most common on higher trims) → Yes, coding/initialization is usually required.
    • The car’s Body Control Module (BCM) and Headlight Control Module need to recognize the new unit.
    • Coding ensures that adaptive functions like auto-leveling, matrix beam control, cornering lights, and high-beam assist work properly.
    • Without coding, the light may turn on but advanced functions won’t work, or you may see a dashboard warning.
Land Rover dealerships and independent shops with JLR SDD/Pathfinder software can perform the coding.
Old Aug 22, 2025 | 05:07 PM
KamboMD's Avatar
not sure why I didnt think to ask Chat...thank you for this information, looks like I'll reach out to the mechanic - maybe thats why he quoted me $1200! Another shop quoted me $700 as well but is 90 minutes away from me.
Old Aug 22, 2025 | 07:32 PM
KamboMD's Avatar
Just was quoted $285 for the coding which they'll need the car all day.
Old Aug 23, 2025 | 09:15 AM
wcc18999's Avatar
It should not take all day to do the coding if they are familiar with the JLR software. An hour at most.
Old Aug 23, 2025 | 10:13 AM
KamboMD's Avatar
good to know - I asked if I could wait for it was done(they are roughly 90 minutes from my home) and they said they’d need it for the entire day. They are certified LR mechanics. I reached out to another shop that’s closer as well and waiting to hear back. In the meantime, this fault isn’t causing any trouble is it? I assume no….but assumptions have gotten me in trouble in the past lol
Old Aug 23, 2025 | 11:19 AM
wcc18999's Avatar
It should not cause any issues other than the message you get on your dash.
Old Aug 23, 2025 | 02:18 PM
KamboMD's Avatar
Well update - it appears it has fixed itself and the code has been gone all day today after a good 100 miles put on it. Might just be temporary though.
Old Aug 24, 2025 | 03:53 PM
GavinC's Avatar
No coding needed.
it’s a straight swap. 20-30 minute job.
