Hood hinge stud corrosion
Not to be an alarmist but... I think we will look forward to corrosion on attachments on these L663's.
Pic below of side hood hinge stud (on hood).
2020 Defender, 19K miles, car delivered Jan 2021 so 27 mos old. Car has never seen road salt (maybe once but for a couple hours on Mt Hood).
Was removing it to install a ditch light style bracket for a GMRS hood antenna.
Corrosion has set in... ugh. This will not sleep.
Location: Drivers side hood hinge, attachment point on hood
The reason for removing the nut - installing this bracket for a GMRS antenna
Corrosion is minor and no big deal whatsoever now, but ... What sucks... is that in 5-10 years, these studs in high corrosion areas may fail and break off ... which is then a bit of an issue to attach the hood.
As the owner of an RRC I'm somewhat attuned to corrosion on dissimilar metals (aluminum, steel, stainless, etc). Also, if anyone familiar with what is happening on the latest bodystyle Jeep Wranglers... same thing.
WAFOX (04-20-2023)
LPS-3 works well for this kind of application as well. I'm a Series IIA owner and swear by it.
nashvegas (04-23-2023)
BTW I do have and swear by Boeshield T-9... it's more of a lubricant than a longer term corrosion preventer though IMO. I do use it on lots.
Myron (04-23-2023)
