'Hood Open' error. Anyone had this?
Trying to lock the car and it double beeps twice. Check inside and when the ignition is on, the msg 'Hood Open' pops up on the driver screen (same on my phone app). Check online and it's a common problem on other Land Rovers, and it's a switch under the passenger-side hood catch that's either loose or failed. My car is only a year old.
Tried starting the car and the whole system is saying nothing is available, the steering is locked, can't select any gears, ie undriveable.
So tomorrow morning i'll be doing the reset for the battery that's under the floor just behind the passenger seat - let's see if that works.
If not, it's a flatbed tow to my dealership.
Bad news. This morning I removed the black -ve terminal, left it 10mins and re-connected. Same as yesterday: Steering locked, no lights on gear shift, no driving assistances available.
More than undrivable, not sure how recovery are going to get a steeringless and gearless car onto the flatbed.
PaulLR is right to advise participatory caution. The new Land Rovers have more NANNY guards than the prior generation. I too would be confirming they are following the recovery guidance in real time.
I suffered the same hood latch issue you are having when I failed to connect the hood latch line during my winch install on my Defender. Fortunately, I learned from my LR4 the location and design logic of the Hood latch and could easily fix it.
There are several videos on the PowerfulUK ltd or you tube which show the hood latch fix, if you are into being a self-mechanic.
GrouseK9 (07-25-2022)
The car was stopped and lifted on wood blocks under all four wheels
I seem to recall it did not let me start it until I fixed the beep-beep issue. It was not running, was in park at the time with the parking brake set. Without starting it, I could not shift out of park or take off the parking brake in any case. Or so I recall it.
My hope was I did not by mistake cut the signal wire to the latch -- a little stress for sure. Fortunately, I had only neglected to re-attach it. I do not recall checking the steering lock -- but I have no doubt that is likely the case which you describe.
I continue to find the NANNY requirements to always use the parking brake and not being able to shift out of park without the doors all closed hectoring beyond what I accept. The LR4 generation did not include these points of vehicle disablement.
Good luck with the towing people ....
Thanks Trio - I'm still waiting for Recovery to arrive, but I'll post once the dealership let me know what's happening.
Ok, recovery arrived: The engine must be running throughout recovery; there's a release under the hood that puts the vehicle in Neutral (see pic below) but also double-check the Park brake is DEFINITELY off, if not the rear wheels are locked, as happened to me just now. Dealership were great walking me thru what to tell the recovery guy who knew a lot, but not enough to get my car on his flatbed.
[Picture shows the lever cable with the yellow label; the lever on the end is shown closed and needs to be opened to 90° and it'll release the wheels into neutral]
The following 2 users liked this post by Elektrapops:
PaulLR (07-25-2022),
TrioLRowner (07-26-2022)
