Is the integrated air compressor worth the cost?
Old Oct 3, 2020 | 07:57 AM
PaulLR's Avatar
Default Is the integrated air compressor worth the cost?
Did anyone order the onboard air compressor?
Most of the time I don't bother airing-down my LR4 tires when driving on the beach. But sometimes if I park on an uphill incline, when I attempt to leave the LR4 will sink into the soft sand rather than move forward which means I do need to air down. Then I take the 10 minute drive home on 20 psi tires and use my big air compressor to inflate the tires. Onboard air would be nice, but I have a few concerns:
- What is the run time? Enough to inflate all 4 tires? I have tried some small portable compressors and they either timeout when overheating or actually melt.
- How much space do you lose in the rear cargo area? It's already smaller than my LR4 cargo area.
Thank you in advance for your feedback.
Old Oct 3, 2020 | 01:15 PM
Guapo's Avatar
I have the air compressor. I like it. You set the pressure on the dial and it will inflate or deflate to that pressure automatically. No fiddling with pressure gauges etc. I’m glad I have it and have used it a lot off-roading.
Old Oct 4, 2020 | 07:32 AM
PaulLR's Avatar
Hmmm...deflate too. That is enough reason to order it. Funny, with my Defender build at $87K, I was tempted by the new SQ7 at $90K. I just couldn't get past it having regular tires (not run flats) and no spare tire. So instead of a can of fix-a-flat, with the Defender I'll have a full size spare and an onboard compressor.
Old Oct 4, 2020 | 05:47 PM
TrioLRowner's Avatar
My local dealer is not yet released to order the on-board compressor, so I have moved over my Viair 300P portable compressor (ordered on Amazon) from my LR4 to the Defender. It works great !
Old Oct 5, 2020 | 11:45 AM
avartanian's Avatar
It's a great option. Like Guapo says, you turn the **** to a preset PSI and it either inflates it or deflates it to that set PSI. The Land Rover air hose that comes with it also easily reaches all four tires.
Old Oct 18, 2020 | 08:49 PM
Apxlvr's Avatar
Can the compressor be installed afterwards or needs to be a factory installed option...would make great use for airing up the road/mtn bike as well
Old Oct 18, 2020 | 09:20 PM
umbertob's Avatar
It has fitting instructions and a part #, so I assume the air integrated compressor can be ordered and installed afterwards - it doesn't look that daunting of an install either for a DIYer.
LAND ROVER ACCESSORY FITTING INSTRUCTIONS
Old Oct 19, 2020 | 06:54 AM
Guapo's Avatar
Yes it can be fitted after you take delivery. Mine was by the dealer. I also saw someone in a new defender facebook group install his himself.
Old Oct 19, 2020 | 11:45 PM
Corgi_Express's Avatar
Does anyone know the power draw on the LR compressor? I would love to repurpose the wiring to power some other accessories, but can't find any specs.
Old Jun 19, 2021 | 02:03 PM
bcstar's Avatar
Anyone installed it themselves with a 3rd row air option?
The instruction video by powerfulUK didn’t line up and I got stuck.
