"Land assist not available" and no power steering on 2023 Defender 130 First Edition
Old Jan 26, 2024 | 04:17 PM
  #21
Defendher's Avatar
How is something like this still a problem in a 24? 3 model years is a long time for this to still be a problem.
The dealer says it will fix the issue, but I have my doubts.
Old Feb 19, 2024 | 02:47 PM
  #22
apaglione's Avatar
Same thing happened to me today. No power steering at all. I disabled the battery, waited 10 minutes and reset the battery. At startup all was fine.
Old Feb 19, 2024 | 03:37 PM
  #23
TeddyG's Avatar
Has anyone had it on P300? It might be MHEV related glitch....
Old Feb 19, 2024 | 04:08 PM
  #24
apaglione's Avatar
I have a 2024 X SE 110. Only 3,500 miles. I also had the issue where the front speakers stopped working (twice). I am starting to get nervous about the electronics.
Old Mar 24, 2024 | 12:19 AM
  #25
Raylimchesing's Avatar
HI Paul.. i cannot find a 10mm terminal bolt,, can you help please, i have this same problem steering locked, with lane assistance not avaiable.
Old Mar 24, 2024 | 06:55 AM
  #26
JBelt01's Avatar
10mm wrench to disconnect a lead to the battery which will reset the computer.
Old Mar 24, 2024 | 07:19 AM
  #27
PaulLR's Avatar
Are you looking at the battery under the passenger seat? The top of the battery has a negative terminal marked with a minus symbol "-" and a positive terminal marked with a plus "+" symbol. There is a silver clamp attached to each terminal and this clamp is tightened with a small bolt. Loosen the bolt on the negative terminal clamp and pull the wire and clamp up to disconnect it for a few minutes. Someone posted that their battery terminals have 8mm bolts, so you may need an 8mm or 10mm wrench or any small adjustable wrench will work.
Old Apr 28, 2024 | 06:48 PM
  #28
Mike_F's Avatar
Well, I’m stumped. 2023 110S with P300.
I lost power steering as I was pulling into the driveway this evening. Fortunately, I had seen this thread and ordered the 10mm insulated wrench.
Unfortunately, 10 minutes of a disconnected negative terminal did not fix the problem.
I rebooted my pivi, but no joy.
I’m on 4.1.1_ installed on 22 January 2024. Is that the latest? Of course there’s no way to force an update. I have good home WiFi when I’m in the driveway, so that’s not an issue.
Hoping it resets overnight. Or I’ll try the battery trick for a longer time period. I’d rather not lose the time it will take to have it towed to the dealer.
Old Apr 28, 2024 | 07:26 PM
  #29
TeddyG's Avatar
I hope there are enough reports to initiate some sort of recall. Loss of power steering is not a small deal.
Old Apr 28, 2024 | 08:04 PM
  #30
Mike_F's Avatar
Just left the battery disconnected for an hour. No change. I’ll call the dealer in the morning.
