Leather Seat Failing
Seats move down and back when you shut off the car. And up and to a set position when you start the car. Turn the **** under the steering wheel to auto.
Land Rover Defender entry and exit mode.
Yes. Common with side bolsters, especially with light colors. You might want to try a different technique when entering/leaving the car to avoid getting worse. On a related note, the upgraded Windsor leather seems to hold much better than the grained leather. Might be an added cost in the beginning, but IMO pays off in the long run.
That's really premature for 30K unless there are extenuating circumstances (big people, rough work clothes, toolbelts etc,) All automotive leather is painted. The "paint" has been worn away. Prevention is the key. To prevent this certain protective synthetic leather coatings can be used. I use a protectant called Colourlock Leather Shield just for this purpose.
If this were my car I'd do the following:
- Repair the worn area.
- Use an appropriate protectant
- Be a bit more careful entering and exiting
SilverSFR (01-16-2024)
