Expedition rack question
Old Jan 14, 2024 | 04:52 PM
mlw911's Avatar
Default Expedition rack question
I’ve noticed the front section of my expedition rack has come a little loose. You can push up and down on it and get a tiny amount of movement. In looking at it I can’t figure out how to tighten. It looks like it ties into the main section of the rack where the foot is but these racks come pre-assembled. Any one have any ideas?
Old Jan 14, 2024 | 11:40 PM
HI Rover's Avatar
5th Gear
Loosen the front rail and either move it back or take it off and you’ll see a couple of bolts that connect the front piece which you can easily tighten. It doesn’t take long.
Old Jan 16, 2024 | 10:42 PM
FareWarning's Avatar
Just be careful when loosening the front rail as those use security torx screws. I don't have the size off hand but it was a PIA trying not to strip it as they initially do not wanna budge. ended up gently taping the bit with a hammer to seat it properly to loosen. Bought my expedition rack second hand and the front was loose as well. Tightening the 2 bolts hidden by the front rail did the trick.
Old Jan 17, 2024 | 08:25 AM
Dokodoko's Avatar
I had the same issue, but the movement was too big to be fixed with just the screws. I took off the front bit completely and wrapped the bits that stick in the roof rack with some masking tape before tightening the screws.
nashvegas
Nov 5, 2022 04:12 AM
mstclair23
Nov 2, 2022 04:04 PM
Tomzsix
Jul 8, 2022 08:02 AM
drowssap
May 28, 2014 12:09 PM
discobob
Nov 21, 2010 05:12 PM
