LED Angel eyes headlight replacement
You may want to check out the thread about it that was started last week. Seems like much of this may be a JLR problem. Contact your dealer.
https://landroverforums.com/forum/20...ng-drl-113207/
As cars go out of warranty these prematurely dying signature LEDs are going to become a huge PR problem for LR. A replacement "premium" headlight (the one with the signature LED) is something like $2300.00, plus labor (and a new headlight may need to be programmed into the electronics, I am not certain any garage could install it.) Used eBay units pop up every now and then but you take your chances, first you need to order the exact match to yours, secondly 1 out of 2 is likely to have an issue when you plug it in (which is why it ended up on eBay to begin with..) I had one halo failure before my warranty was up about 3 months ago, the headlight was replaced under warranty. A couple of weeks ago, the halo on the other headlight went out, but I am past the warranty period. I'll live without it for now, but it's annoying.
