Lift, Bigger Tires, and Spacers?
Old 07-27-2023, 10:01 AM
ORDPA's Avatar
Default Lift, Bigger Tires, and Spacers?
Anyone have experience wheel spacers running a lift and larger tires. My set up is 1.5” lifting rods with 275/60/20 BFG KO2’s. I was thinking about spacers to fill the wheel well better especially since I have wheel arch extensions on also. Looking to some experience reports and size recommendations. I believe I have space on the backside of my wheels for thinner spacers without cutting lugs. Would love to see some pictures of the results if someone has some.
Old 07-27-2023, 10:07 AM
SilverSFR's Avatar
ORDPA,
Please review the Sticky - No lift tire size guide at the top of this forum. Much of the info you are seeking is contained within. The thread talks about both lift and no lift tire sizes as well as different spacers.
Old 07-27-2023, 11:52 AM
ORDPA's Avatar
Originally Posted by SilverSFR
ORDPA,
Already did. Read the whole thread a couple times. It mentions possibly using them but there are no reports on specifically what I am asking. I asked in that thread as well a while back but never got an answer and was informed it was the no lift tire size thread. So I am hoping to get info not contained in that thread. Thanks for the advice though.
Old 07-29-2023, 10:07 AM
ORDPA's Avatar
No one with real info? Guess I will play with it on my end and report back on my findings to maybe help the next person who has the same question.
Old 07-29-2023, 10:54 AM
Ronin Defender's Avatar
I'm running BGF A/T 305/50/20 on my Defender 90... zero rub and no need for front spacers..I did add 30mm spacers on the rear ..
The following 2 users liked this post by Ronin Defender:
GrouseK9 (07-31-2023), Ratledge (08-02-2023)
Old 07-30-2023, 12:05 AM
ORDPA's Avatar
Are you running a lift as well? If so what size? Nice to know and 1+ inch wider tire fits. I have an idea how to test before I order. Was considering 25mm front, 30mm rear.
Old 07-30-2023, 09:36 AM
No lift links, this is all stock, just push the up button..
Old 08-01-2023, 11:52 PM
ORDPA's Avatar
Well it looks like spacers are a no go unless I want to lift more or do some cutting/modification. I have slight rubbing in access mode at full lock. And very little room in drive height. The rub is just enough to take the dust off the plastic. Pushing the tires out another inch would only increase this best I can tell. The rub is only at the front so the plastic over the intercoolers would require modification. Will have to think on that before I do that.
matthewjlove
02-15-2022 09:28 AM
juicyhotsauce
10-19-2018 12:30 PM
DiscoBear159
05-18-2018 01:38 PM
toofaroffroad
09-29-2013 11:50 AM
bsnapp818
11-22-2010 03:20 PM
Quick Reply: Lift, Bigger Tires, and Spacers?
