low speed stuttering
Old Sep 26, 2024 | 02:33 PM
farmer12's Avatar
Default low speed stuttering
Hi, have a 2021 D200 3L 110 thats done 48,000 miles, it's had low speed stuttering for a while, when you pull away from junctions it stutters as if the fuel filters blocked (its had new fuel filter, no difference). Its been back to marshalls a few times but no luck, the last time it did seem to be better for a couple of days but then went back to stuttering. Out of warranty now! has anyone had this problem ? Other than this its been good but this low level stuttering really takes the shine off driving it. thanks
Old Sep 26, 2024 | 03:27 PM
CincyRovers's Avatar
While there are some UK and European-based members on this forum who might be able to help you, this is a US-based forum, and we don't get the diesels here. If I were you, if this problem keeps persisting, take it to the dealer or a reputable independent mechanic. Best of luck!
Old Sep 26, 2024 | 05:01 PM
lightning's Avatar
As above
Try a post on the U.K. forum where we get the diesel engines, you may get more advice there.
Be sure to post on the L663 Defender part of the forum and not the "classic" Defender section.
defender2.net
Old Sep 27, 2024 | 02:22 PM
silviu's Avatar
Try Defender2net Forum, the L663 section.
Did you check the compression? It sound a bit like the issues the old 2.0l 4-cylinder engines are having in the Discos and Defenders. I also have a D200 3.0 so this sorts of posts worry me
Volkov
Dec 31, 2015 02:32 AM
kog50
Sep 20, 2011 01:54 PM
sn1987
Aug 15, 2009 09:17 AM
cst756
Aug 5, 2008 09:16 PM
ElMaestro
Aug 3, 2006 11:38 PM
