Mod of easy accesible front tow hook / loop
Old Apr 11, 2021 | 07:59 PM
Defendit..'s Avatar
Default Mod of easy accesible front tow hook / loop
Remove cover, sanding, masking, spray metal primer
3 layers rescue orange spraypaint and 2 layers clear gloss
Bolts black
cardboard, masking tape, measuring, cutting
cardboard attached to cover and Cutting with Jigsaw fine metal blade
Adding thin rubber U profel inside ( unfortunately to short)
cover back on
Adding strenght and closing the gap with alu corner profel
Spraypaint black
Install with selftapping screws and some hybride sealant black
So for now it is accesible and neat, will buy later a HD undershield protection.
This solution works fine, one drawback it's like a scoop for mud.
So I did mount a piece of alu diamond plate behind.
The holes are present behind there, just tapping in some 6mm thread in the diamond plate and 6mm screws.
Old Apr 11, 2021 | 10:42 PM
Mark1107's Avatar
You could have saved me 500 bucks!
SOMEBODY SLEPT AT A HOLIDAY INN LAST NIGHT!
Old Apr 12, 2021 | 07:30 AM
merrion13's Avatar
Nice work, definitely a cleaner version of the mod I had previously posted. I pulled a stuck truck out of the snow this weekend, sure was glad to have the front eye exposed to save me the 10 minutes of fiddling with the plastic cover! Well done-
Old Apr 12, 2021 | 04:33 PM
Defendit..'s Avatar
Thx !, I'am aware that this is not an HD solution - but for let's say 90% of the owners of a New Defender it will do.
Old Jul 22, 2021 | 06:22 PM
looperdolly's Avatar
8th Gear
Sweet! Thanks for taking the time to post your solution. Looks great!
Old Jul 3, 2023 | 04:30 PM
Defendit..'s Avatar
Default Update after 2 years
Old thread update.
After over 2 years with my cheap mod of the easy accessible towhook I can confirm it stood out pretty good in almost all conditions.
But accidental I ran into a brand new genuine undershield protection VPLEP0436 for under $ 150,- , so that was a no brainer.
Did have it powder coated first in a inox champagne color to match best possible to the Silicon silver skids,
a fresh layer of red paint for the towhook was also badly needed.
Let's scratch this one.. 😀
Old Jul 5, 2023 | 08:37 AM
stevemfr's Avatar
Looks nice. Under $150 is a bargain considering the overpriced retail of the OEM piece. Mine is getting an aftermarket skid plate for this reason.
whowa004
144
Sep 3, 2024 11:02 PM
dmannrover
Jul 31, 2019 11:57 AM
LR03NJ
Dec 4, 2017 12:38 PM
demonlarry
Feb 17, 2011 09:56 AM
