New 2020 Defender Lift Kit by Johnson Rods
Old Jul 16, 2020 | 02:47 PM
Johnson Rods's Avatar
LR Forum Vendor
Default New 2020 Defender Lift Kit by Johnson Rods
Check out our new Defender lift kit: New Defender Lift Kit from Johnson Rods
Follow us on Instagram : @johnsonrods
Shown below is a dealer installed Johnson Rod 1.5 inch lift kit with 275-60-20 BFG KO2 (33 inch) tires.
Many Land Rover dealers use our lift in their showrooms as an upgrade package. Our lift is preferred because of the quality of construction and materials that can stand up to extreme hot and cold conditions without breaking down. We use 3/16 high quality stainless steel which provides strength and durability. Our rubber attachment points are extra thick just like the original Land Rover part which insures a tight non slip connection and which makes them less susceptible to cracking and breaking down under harsh conditions. In fact, the rubber has a high resilience and tensile strength, abrasion resistance and operates effectively in temperatures between -60 degrees F to 180 degrees F.
Johnson rod 1.5 inch lift with 33" tires
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Jul 16, 2020 | 04:40 PM
LR Forum Vendor
__________________
Old Jul 16, 2020 | 04:43 PM
LR Forum Vendor
275-60-20 with 1.5 inch Johnson Rod lift Thank you Chris at Les Schwab Tires
__________________
Old Jul 16, 2020 | 04:44 PM
LR Forum Vendor
Thank you Joe for this beauty. 275-60-20 BFG KO2 tires
__________________
Old Jul 16, 2020 | 04:45 PM
LR Forum Vendor
Johnson Rod 1.5 inch Defender lift kit 33" tires
__________________
Old Jul 22, 2020 | 05:52 PM
LR Forum Vendor
Default 2020 Defender lift kit by Johnson Rods
275-60-20 33" with 1.5 inch lift:
Dealer installed. Ask your dealer to install Johnson Rods on your new Defender.
__________________
Old Aug 6, 2020 | 01:31 PM
LR Forum Vendor
Our 1.5 inch lift is all you need for 33" tires 275-60-20
The 1.5 inch lift provides the best overall ride quality.
Check our website link below in the signature for more:
__________________
Old Aug 9, 2020 | 08:46 PM
mgreenawald's Avatar
This looks great. I want to do this but don't want to affect my warranty. How have dealerships handled these mods? I assume it is on a dealer by dealer basis on whether they will do it and then support it from a warranty perspective; is that accurate?
Thx in advance.
Old Aug 10, 2020 | 04:27 PM
LR Forum Vendor
Many of the dealership will do the install if you ask them for it as part of the sale or for service.
Over the last 10 years we have not seen this to be an issue.
You can always simply swap back to the original rods.
__________________
Old Aug 11, 2020 | 02:06 PM
LR Forum Vendor
This new Defender is set up nicely with our 1.5 inch lift and is running 265-60-20 BFG KO2 tires at 32.5 inches.
The owner chose a slightly smaller diameter tire than 33" to leave more room for articulation. Looks great!
Click on our website in the signature line below: Don't forget to follow us @johnsonrods on IG.
New Defender with 1.5 inch Johnson Rod Lift 265-60-20 32.5 inch BFG KO2 tires
__________________
