New 2020 Defender Lift Kit by Johnson Rods
Old Dec 20, 2021 | 01:10 PM
  #101
Johnson Rods's Avatar
LR Forum Vendor
Default In the Christmas spirit with the amazing D90!
This customer is in the holiday spirits with his First Edition Defender 90 towing around Santa and Mrs. Claus in their sleigh to share the Christmas spirit with hundreds of children! Thank you for sending in the wonderful photos!
[1.5 inch lift kit, 275/55R20 BFG tires with 30mm spacers]
__________________
Please visit our website: https://www.Johnsonrods.com
Follow us on Instagram: @johnsonrods
Visit our vendor section:Johnson Rods Vendor
Old Jan 6, 2022 | 07:12 PM
  #102
drcoop's Avatar
Is an alignment necessary and important after 1.5" rod install?
Old Jan 13, 2022 | 01:28 AM
  #103
RogueClimber's Avatar
6th Gear
To quote the Johnson Rods website:
To accommodate full time use, an alignment to adjust the wheel camber is recommended.”
Old Feb 12, 2022 | 07:45 AM
  #104
MERCTwister's Avatar
Banned
I really want to lift my D90 on coils 1.5-2" that doesn't cost $1000's. What are my options??
Sorry to hijack
Old Feb 13, 2022 | 10:51 AM
  #105
Nanozic's Avatar
Sorry to hijack
Maybe you've already seen this, but this is the only coil lift solution that I have seen so far.
https://www.etsy.com/listing/1160897...tm_term=so.slt
Maybe someone will make puck inserts that would work with factory coils and be much cheaper, but I just haven't seen one yet.
Old Feb 13, 2022 | 10:58 AM
  #106
Banned
$1300 for some springs seems insane to me considering all the cheap coil and or puck spacers for coils for older models. I will wait a bit
Old Feb 13, 2022 | 11:43 AM
  #107
nashvegas's Avatar
Default Auto Access Mode
Originally Posted by Johnson Rods
Here is a nice Johnson Rods dealer install by Las Vegas.
You can order your Defender to come with Johnson Rods or purchase them and have them installed at any time by the dealer.
Johnson Rod 1.5 inch kit 275-60-20 33"
EDIT - PROBLEM SOLVED - NEVER MIND! . After a day of driving around, tonight it started going into access mode when I park. How odd. It's like it needed to recalibrate. I probably did 3 drive cycles, and 25 miles on the car.
Hey. @Johnson Rods Question ….Is there a reason why installing the 1.5” lift rods would prevent the Defender from going into auto access mode? Happening on my 2020 110 and another forum member’s too.
(I can confirm auto access mode functioned properly and is selected in pivi pro)
Thank you
Old Feb 14, 2022 | 12:33 AM
  #108
Ehloo's Avatar
how often do you rotate the tires. AT tires need to be routed much more frequent. every 5k miles
Originally Posted by Johnnycat
Hey I've got the 1.5" lift rods and some General Grabber ATX tires in 275-60-20 on our Defender and took it to Land Rover to get it aligned. They did note that they couldn't get it perfectly to spec since we were at the limit of one of the adjustments. Now a few months later I am noticing some pretty heavy wear on the outside edge of the tread of the front tires. Has anyone else who has the same lift and size of tires had issues getting it aligned to spec and/or seeing excess wear like this? I knew there would be uneven wear but was not expecting something this bad. I could have sworn others were able to get aligned properly after the lift was installed.
Front Tires
Rear Tires
Old Mar 11, 2022 | 10:42 AM
  #109
Zilla's Avatar
I know this is a Johnson rod post, but on the same topic, different brand..
Does any have 1” proud rhino lift rods on 275/55r20?
Old Mar 15, 2022 | 07:18 PM
  #110
GetOutTheWay's Avatar
How are you getting 275-60--20"s on? I have a 2021 D90 400 with 20's and stock wheels. There is but 5mm's of room between the front tire and a suspension part. I have air suspension. Is the coil set up without a suspension part in the way the reason you can run larger tires? I also put a 1" lift on my Defender and it does not change the suspension part that is in my way. All I can figure out is to go for aftermarket wheels with far less off sets. So confusing..
