New 2022 V8 build...
Old Jun 29, 2021 | 07:15 AM
PaulLR's Avatar
Originally Posted by NoGaBiker
Basically, there are 6 pipes that exit the engine and run to parts of the cooling system. The manifolds are cast aluminum, and the pipes insert into them and are glued — yes, glued — in place. When the glue lets loose on one, bye bye. So you pull the motor (you can’t get to 3 of the pipes with it in situ) and either weld them together or drill through the pipe and insert a small bolt and locktited nut straight through the middle. Problem solved (for about $2300 labor, thank you very much.)
You have to wonder what engineer decides that gluing pipes and plastic coolant parts are a good idea given the heat and pressure they have to endure. Then again, GM has had over 60 years to get their 350/5.7 pushrod engine sorted out, so no wonder it runs for 510K miles.
Natanael Prendi
May 6, 2021 01:18 PM
SFLo
Range Rover L405 (Fourth Gen)
Dec 21, 2020 10:33 PM
bates
LR4
Nov 6, 2015 11:42 AM
yloDiscoII
ROAMING WITH FRIENDS
Oct 26, 2011 09:49 PM
Landzu
Mar 21, 2006 12:42 AM
