New rear differential
Old Jun 16, 2024 | 10:45 AM
DefenderSISU's Avatar
Default New rear differential
Hello everyone, I just wanted to let everyone know that my rear differential had to be replaced because I believe the locker was not working properly or loose as it made a thump every time I went around a corner or from reverse to forward. Just a FYI. Have not seen the bill yet but I believe it is in the neighborhood of 7k installed.
Old Jun 16, 2024 | 01:53 PM
lightning's Avatar
l've heard of this before, but flushing and changing the oil usually cures it.
Old Jun 16, 2024 | 02:02 PM
GavinC's Avatar
Yeah. Flush it a couple of times. That is the LR service bulletin for these.
A known design failure apparently. Sounds like a well devised kick-the-can bandaid by LR. Get the vehicle out of warranty, then ask you to bend over choose your barrel.
At 62,000+ miles and $7k for the OP, they seem to have found him a nice rusty one.
I'd be just flushing the diff and living with the clunk till I sold it on.
Old Jun 16, 2024 | 03:12 PM
Default Flush
I had it flushed but only got worse. So I took it in for an oil change and had them look at it and they decided to change it out. I asked to see it before they ship it off but I don’t think they will let me have a look at the interior.
Old Jun 16, 2024 | 03:31 PM
Norsk's Avatar
Is the rear diff the same in the V8’s? Seems like all these have been in P300 and P400’s.
Old Jun 17, 2024 | 05:10 AM
sarek's Avatar
They are similar but the gear ratios are different.
Old Jun 17, 2024 | 05:14 AM
sarek's Avatar
The noise will get very loud and almost intolerable. The flush typically remedies it for a short time but the noise comes back worse in most cases.
Old Jun 17, 2024 | 05:56 AM
lightning's Avatar
Well, reading this l am glad l didn't specify the off road pack with e-differentials then.
In the U.K. l've read of similar issues but flushing and changing the oil seems to permanently cure it.
Old Jun 17, 2024 | 06:06 AM
sarek's Avatar
Yep. We do not spec them in our builds. This is one of a couple reasons we prefer the standard differential.
Old Jun 18, 2024 | 07:53 AM
Randino's Avatar
Wouldn't the diff be part of the powertrain? That should have a much longer warranty.
