No Lift tire size guide (work in progress)
Old Jun 4, 2022 | 03:43 PM
  #331
Mcdooogs's Avatar
Originally Posted by GavinC
Hey @Mcdooogs Thanks for the info. I wanted to ask if you are using a lift.
I've got some 18" alloys coming soon(ish) and looking at the same tire. 265/70R18 MT Grabbers. With the added 0.6" diameter and 0.3" height increase I'll just barely fit in my garage so a lift is not something I'm interested in.
I know you mentioned in your TopofTheWorld trail post that you have lift and sliders but wasn't sure if you'd run this setup without the lift for a bit.
Any info on rub without the lift on these tires. How close was it to rubbing.? The alloys I'm getting are 30+ offset so will be closer than OEM at full lock.
I have no lift actually. i own 1.5 inch rods but have never actually installed them. The 265/70/18 tires havent rubbed as far I can tell, and they’ve been flexed on some pretty technical trails
Old Jun 4, 2022 | 04:53 PM
  #332
GavinC's Avatar
@Mcdooogs
Thanks very much for the info. Sounds like they should work just fine on the Tuffants. They seem to be the same sizing as the BFG KO2s but I think a MT would come in handy. Still in two minds.
Love how your Defender looks with the sliders and steelies. Most excellent.
Old Jun 4, 2022 | 10:29 PM
  #333
DEFENDER2020's Avatar
Originally Posted by Eitan
Did you end up going this route Roy? I've heard really good things about the AT3W's from Jeep people as well, but not so much in the Defender context. Would love some feedback if you got any. I'm in Chicago and people are reporting they are better than KO2's in snow, which is a big thing for me.
Unfortunately ,I haven't. My defender has been experiencing a loss of power ( about 25%) after about 30 min. of driving so it is at the dealership (see separated thread). I can't do anything until they find out what is wrong with it because I don't want them telling me it is the oversized tires.
I have been leaning towards the Nitto Recons Grapplers, but I know they are not as good in snow compared to the Falkens. [/QUOTE]
Old Jun 7, 2022 | 03:22 PM
  #334
humbertor's Avatar
7th Gear
Hello everyone new to the forum.
so I’m having an issue right now.
I have a 2022 D90 S with 20 in wheels from factory.
I bought 18 steels from a 22 d110 base, went to install the wheels and they did not fit in the front of it, caliper issue. Has anyone had that issue before? If so what’s going on I thought that p300 should work with 18 wheels.
if anyone can help me I will be greatly thankful.
Old Jun 7, 2022 | 04:20 PM
  #335
GrouseK9's Avatar
@humbertor - Welcome to the forum. Regrets for the challenges. It's fairly common that P400's try to go to 18" wheels and fail. The weren't designed for it. The front tires have a dampener that gets in the way and the rear has larger calipers that they don't fit on. If you want 18's on it, you will need to either replace the calipers or grind the existing calipers. If you want to replace them, start here: Link. Lucky8 sells calipers that should fit. The other way is to grind the brakes down. The risk is on you re: both of these options as they invalidate any warranties in there and anything that happens as a result is on you (aka, damage, carnage, injuries, etc.). Many folks have just gone the grind route. Here's a link to the thread. You'll find as many proponents of one path as the other. Up to you re: which works best. Good luck!
Also, depending on the wheels, you may want spacers as well. The wheel/tire set up doesn't always fit. Pro-tip: Used the "Advanced" search. Much better than just Search if you want to read all the threads re: spacers.
Old Jun 7, 2022 | 04:30 PM
  #336
humbertor's Avatar
7th Gear
but I though the defender 90s with the p300 engine had the small brakes or am I wrong?
Old Jun 7, 2022 | 04:31 PM
  #337
GrouseK9's Avatar
Missed that. If you have a P300, different story.
Old Jun 7, 2022 | 04:33 PM
  #338
humbertor's Avatar
7th Gear
If I have a Defender S it only comes with the p300 engine right? Which brings the small calipers
Old Jun 7, 2022 | 04:39 PM
  #339
user 729788's Avatar
Banned
I believe since you have the 20" rims, JLR installs a small round chunk of aluminum to help scrape the mud off the inside of the rim. It is easily removed and the 18" rims will fit. If you could post a picture of the offending piece, someone here can help you out, but the mud scraper is my guess.
Old Jun 7, 2022 | 04:47 PM
  #340
Banned
See post 127 of this thread.
