No Lift tire size guide (work in progress)
#471
No rub at full lock with these 33" beauties? I run 32.6" and they're as close as a gnats whisker to the wheel well at full lock in access. I've not seen anyone run this size without a 1.5" lift.
GrouseK9 (08-15-2023)
#473
#474
Oops my bad. I meant to post that in the Johnson Rods thread. Guess I was not paying attention. Since I am here now let me answer the first post in the thread question about these tires fitting without a lift. In access height with the lift they are so close you can not go lower without rubbing. I suppose if you disabled the auto access height they might fit without a lift however it it would be very very close. I figure my access height is very close to normal drive height with factory rods.
#475
The following 6 users liked this post by v35:
Defendit.. (08-06-2023),
jpschwinghamer (07-04-2024),
MattF (08-09-2023),
Ratledge (08-06-2023),
richmeyer (11-19-2023),
and 1 others liked this post.
#478
#479
Does the Defender recognize two different sets of TPMS? In other words, if I am swapping between two sets of tires (all 5 wheels and tires), a 22 inch with stock tires and a 20 inch set with All-Terrain tires each having their own TPMS, will both of these sets be recognized by the vehicle when I swap them? So when I change to my street tires will the TPMS read those pressures and when I put on the Off-road tires, will it read those pressures?
#480
AAJR (08-30-2023)
