OEM Rail Removal Issues for a Rack
Old Jun 10, 2022 | 11:03 AM
  #61
GrouseK9's Avatar
Two brilliant suggestions.
Old Sep 16, 2022 | 08:45 PM
  #62
EDWARDA's Avatar
6th Gear
Removed the roof rail bolts today. Patience and heat seemed to do the job. You could tell the front 4 bolts were much harder to remove.
Old Sep 20, 2022 | 08:50 AM
  #63
GrouseK9's Avatar
Nice rack!
Old Sep 21, 2022 | 02:12 PM
  #64
EDWARDA's Avatar
6th Gear
Here’s the finished project. I’m really pleased with how it turned out.
Old Oct 28, 2022 | 11:00 PM
  #65
Adamalli's Avatar
Just installed my front runner rack. I was all prepared for the bolts to have lots of loctite and need some heat to loosen them. To my surprise all the bolts came out with not a single drop of loctite on them. Guess I will be sending back that induction bolt heater. I have a 2021 P400 SE.
Guess I got lucky
Old Oct 29, 2022 | 07:47 AM
  #66
Tartan's Avatar
You should reinstall them with loctite (blue only) if you want your rack to be secure.
Old Oct 29, 2022 | 08:57 AM
  #67
Adamalli's Avatar
Yep already did that
Old Oct 30, 2022 | 08:20 AM
  #68
sarek's Avatar
Honestly not sure why some companies chose to not use the factory roof rails to mount the rack. I have a Defender with a Voyager rack at my shop and noticed how they used the mounting bolts to mount the rack and kept the rails in place. I had heard how difficult it was to remove these bolts, so, unless they have to be removed, why design it to require removal. Attaching a rack in the same way as the factory Expo rack using the t slot in the roof rails seems like the obvious choice. Also makes the rack very easy to remove. Just my 2c.
Old Jan 9, 2023 | 11:56 PM
  #69
Dfnder's Avatar
Out of curiosity, would anyone be interested in selling their roof rails that they’re not using? I’m in the northeast and mine are damaged. I feel like with shipping it may end up costing me as much as OEM but shot in the dark!??
Old Jan 10, 2023 | 12:07 AM
  #70
racerpeter's Avatar
I've got a set, send me a DM!
