Pivi Pro 2 Settings
Old Sep 30, 2021 | 01:12 PM
clubguy's Avatar
Default Pivi Pro 2 Settings
My 2022 Land Rover Defender Pivi Pro 2 GPS was displaying gasoline prices on the map as diesel prices...not petrol...here in the US. It seems that the software update on 9/23/21 removed the prices from the map, but now my weather map is showing temperatures in Celsius, not Fahrenheit...in the US. Does anyone know how to change this setting?
Old Sep 30, 2021 | 02:26 PM
bakerman's Avatar
At this point there is not a way to fix the Celsius. Mine is doing the same thing and i've had several customers ask about this as well.
The Brits are trolling us.
Old Sep 30, 2021 | 02:58 PM
Eitan's Avatar
Still not over 1776 most likely...
Old Sep 30, 2021 | 03:13 PM
GrouseK9's Avatar
That was so good that I'm now going to buy all future Rovers from The Much Honorable David Justin Reginald Lawrence Houston, III (I had to look up how to address a Baron).
Old Sep 30, 2021 | 03:20 PM
bakerman's Avatar
Old Sep 30, 2021 | 09:31 PM
clubguy's Avatar
If you go into settings and units of measure, change it from Fahrenheit to Celsius and then back again, the weather app shows Fahrenheit until you shut the car off again. So, it's a temporary fix.
Old Oct 1, 2021 | 07:32 AM
GrouseK9's Avatar
@clubguy - I think that kind of stuff is what comes up when I google the definition of PITA.....
Old Oct 1, 2021 | 08:14 AM
johnsonmc2000's Avatar
No we are not over it! Although, working with us to sell the Aussie's their nuclear submarines and scuttling the French order got you some great points.
Old May 6, 2022 | 11:13 PM
user 729788's Avatar
Banned
Hello Group,
I picked up my D90S today and I am working through setting up the Pivi Pro to suit my needs. The only thing I am hung up on so far is the unit settings. I went into the main settings - vehicle - units and set it to miles (instead of km) and everything in Apple car play shows miles on the map and turn by turn. If I turn off Car play and use the Pivi Pro navigation it still shows KM in all distance and turn by turn on the big display. I have the combo analog/digital dash and it shows mph instead of km/h on the digital portion yet if I go to the map all directions there are in KM as well. I did a Pivi reset by holding down the on/off switch until it rebooted but no luck doing that either. Is there another place where you have to select units for the Pivi Pro navigation page? Thanks for any help!
Old May 7, 2022 | 03:03 PM
Banned
After fooling around for a couple of hours I was able to fix the above issue ^^^^^^^^^^ so I thought I would post the fix. I remember at the dealership we set up Carplay before going into the settings menu and setting the units. I thought maybe somehow Carplay was overriding the Pivipro map since the units were initially in kilometers. I deleted my phone, rebooted the Pivipro and went into units and selected miles but still no luck. I continued to play around with the settings without having a phone connected since I figured that would take the phone and Carplay out of the issue. After toggling the units back and forth numerous times, I finally tried toggling trip units back and forth (even though it was initially set for miles) and once I set the trip units back to miles, everything started working properly both on the PiviPro and on the smaller map display on the instrument panel. Hopefully this will help someone else that may have the same issue.
Vin60
Dec 9, 2021 07:46 AM
karlos73
Jul 20, 2021 08:12 PM
Leegundus
Jul 15, 2021 08:10 PM
willTriBeca
May 30, 2021 02:15 PM
par@pelle.se
Feb 19, 2021 04:11 PM
