Pivi Pro 4.4.0
Old Jan 13, 2026 | 09:03 AM
  #21
RickBullotta's Avatar
6th Gear
There are anecdotal stories of an "update to the update" flowing for some P500's.
Old Jan 13, 2026 | 04:48 PM
  #22
sarek's Avatar
There is a rollback to 4.3 that fixes the problem
Old Jan 13, 2026 | 08:41 PM
  #23
Vadiable Paradox's Avatar
A long while ago, one of my family members noticed that Windows becomes cantankerous and refuses to do obvious things when it wants you to install an update.
I'm starting to suspect that Pivi is just like that - I haven't had a single problem with 4.3.0 since it was released... until 4.4.0 upgrade message started showing up. Since then, it froze on me on at least four different occasions, every time on vehicle start, and every time, annoyingly, I noticed it only after I was driving for a few minutes, already on the street or on the highway - it would start, connect to Android Auto, but the audio would be dead and audio controls both on the steering wheel and on the dashboard would be non-functional (no response on the screen), along with the clock. At the same, the Android Auto map would work just fine.
Is it just mine, or is it a pattern?
Old Jan 14, 2026 | 08:24 AM
  #24
A1C6's Avatar
The more you seek, the more you shall find.
Old Jan 14, 2026 | 09:36 AM
  #25
H1Tad's Avatar
with regards to AA, always make sure your phone itself isn't on DnD mode. If it is, all of your audio will be muted and you'll literally drive yourself batty trying to figure out why you can't hear anything.
Don't ask me how I know.
Old Jan 14, 2026 | 10:34 AM
  #26
WTFChuck's Avatar
Please share how one can initiate a ‘rollback’. That has always been a concern for many of us. If there is a glitch or gremlin in an update, how do we revert to an earlier version of PIVI?
Old Jan 14, 2026 | 12:48 PM
  #27
Disco V's Avatar
So I got the prompt for 4.4.0 this morning.
I'm a non V8...should I accept the update or should I sit it out for a while?
Old Jan 14, 2026 | 01:28 PM
  #28
nashvegas's Avatar
My 2020 110 P400 updated to 4.4.0 overnight. This morning at first startup I noticed I had amber MIL light as I was moving the car out of the driveway - which was not there yesterday.
Pulled out the Gap IIDTool to see what was up. You can sort codes in there to figure out which ones triggering the MIL and there was only one: ABS / Anti-Lock Brake System Control Module - U0100-00 (AB) Lost communication with ECM/PCM This is a code when communication to a module is lost on the CANBUS. Cleared it, drove ~30 miles, MIL has not returned.
I was not seeing any drivability issues and no brake or DSC warnings. This appears to be a one-time post-update CAN issue rather than an actual problem with the car.
That said, given what V8 owners just went through with this same update I’d say this timing is… not confidence-inspiring. This little surprise delayed a separate project I was about to start on the car by about 90 minutes. Thanks, JLR.
Posting here mainly as a data point for other P400 owners.
Old Jan 14, 2026 | 02:08 PM
  #29
Sir Lands-a-lot's Avatar
Going to make sure I have no error codes before doing the update o my P400. Not initiated mine as yet as I thought I'd wait a week or so to see what I am in for before doing this.
Old Jan 14, 2026 | 04:13 PM
  #30
Disco V's Avatar
2024 P400...will decline update and sit on sidelines for now.
