Powering roof top light bar
So I've had a Front Runner slimline 2 roof rack for a while now and just recently got an LED light bar to mount to the front of it. Problem is nobody has a really good idea as to how to get it wired. Have any of you wired a roof top accessory and if so how? Thanks!
I ran wires for solar from the rear compartment. The a-pillar doesn't seem to have enough clearance for heavy cables.
https://landroverforums.com/forum/20...lution-105438/
Scotty2Thumbs (04-19-2022)
@Scotty2Thumbs - Play around with the Search (be sure to use "Advanced") and you will find a lot of threads on the topic. Or, you can go to Lucky8 for their install instructions: Link. They did a GREAT service to the community with these, so buy a t-shirt or throw them a shout out if it helps. Better yet, buy something! They have a lot of quality options.
Good luck and post pics of your experience!
For wiring into the engine compartment, i think people generally use the roof channel to under the A pillar cover.
i’m planning on doing that for possibly the lazer lamps roof pods, if/when i can get over my nervousness regarding having to splice into the headlight assemblies to enable them with auto highbeams
here’s lazer lamps install instructions, they show using the a pillar https://www.lazerlamps.com/media/mageplaza/product_attachments/attachment_file/d/e/defender_roof_pods_-_linear-12_-_fitting_instructions_-_uk.pdf
