Premium LED Headlight Failures: JLR Actions?
Considering asking to swap to standard LEDs when mine inevitably bite the dust to avoid this fiasco again. What mileage did each of yours go out?
I couldn’t get an update from my dealer if the replacement light was any different or a new part number…
That said, I would not change to the standard ones. The halos are a big part of the design that attracted me to the car and they look mean as hell.
2 questions:
1) Does anyone know what is technically happening with these lamps when the DRL LED goes out? Is it a wiring issue/circuit board/etc? I'd love more technical information or for someone with electrical knowledge to disassemble one and do a post up about it -- because I bet it's something simple (albeit in a sealed, non-serviceable unit)
2) I'm starting to wonder if this is a "when" not "if" -- ie will all of our 2020/2021 etc headlamps fail in this manner in the next couple years?
BTW in US, DRL not mandatory. This is not going to be a safety issue I wouldn't think. Perhaps if the actual turn indicators or low/high beams start going out... that's a safety issue and easily a recall (like the X rear lamps).
On my D250 you can turn off the DRL's but it's the basic headlights with no halo.
The DRL seems to be in the same part of the lamp as the indicator as when you use the indicators the corresponding DRL disappears and is replaced by the orange flashing light.
Powerful U.K. are offering replacement premium halo headlights for about 1/5 the cost of LR.
Hopefully these are made elsewhere and will last longer.
2 questions:
If you have an IIDTool (as if we needed one more reason to own that amazing little box...), I think I have found a way to disable the DRL feature in our premium headlights, it involves changing one MultiCAN parameter in the CCF:
MultiCAN-468 FntDRLType
Current: Incorporated DRL and Pos
New: No DRL
After writing the revised CCF to the car, the "signature" LEDs will still turn on along with high or low beams, but will stay off when the main headlamps are off. Automatic headlamps and AHBA, if your car is so equipped, will still operate as usual. Works on my 2020 X.
New: No DRL
hello
i bought my land rover defender 2025 model last month
two days ago message comes up for faulty headlight when i visited the dealership they said glass shattered and wont cover under warranty and ask me to pay 5000 dollars
there is nothing hit to the vehicle , head lamp glass or plastic cover cracked by itself its a manufacturing fault and now dealership not covering under warranty
they are not even bringing this issue to the landrover .i m going to file a case against dealership . anybody else having the same issue please share thanks
hello
