Problems With A Valentine 1 Radar Detector
Old Apr 3, 2021 | 07:33 PM
msgm1's Avatar
Default Problems With A Valentine 1 Radar Detector
I plugged my V1 into my 2021 Defender and it seems to be detecting a constant radar hit from the rear of the car. Does anyone else have this problem? Is it to do within the radar in the rear of the defender for safety?
Old Apr 3, 2021 | 08:59 PM
gts944's Avatar
Disable everything but Ka band and laser on the radar detector. I'm assuming the signal you're getting is K. Many cars seem to emit K band now related to radar cruise control and other driver's aids. Hopefully local law enforcement in your area doesn't use K.
Old Apr 4, 2021 | 07:22 AM
PaulLR's Avatar
Is it the original V1? If so, upgrade to the generation two V1. You will be so glad you did. No more constant beeping from the rear of every Honda product or every oncoming Volvo and Infiniti. And it is amazing at finding Ka radar far in the distance.
Just be sure to mount it to the left of the mirror where there is that clear glass cut-out. I ran the cord across the headliner, down the A-pillar and across to the center console socket plug. Use a credit card or plastic putty knife to stuff the cord behind the A-pillar. Just need to pull off the panel on the left side of the dashboard and the exposed screws make that easy. Then remove the panel under the steering wheel to bring the wire across.
On my LR4 I just tapped into the dome light wire near the rearview mirror to power the V1. But with the forward camera and and other electronics inside that Defender front headliner console, I wasn't confident tapping into that wiring.
Old Apr 4, 2021 | 10:42 AM
carlmuck's Avatar
The guys at "powerfuluk.com" have a plug and play harness to pull power from the overhead console.
I may get that for my escort.
Old Apr 4, 2021 | 05:29 PM
Michael Cip's Avatar
It’s not ignition on. Is on full time battery. It’s fine as long as your willing to turn your detector on and off each time you dive
Old Apr 4, 2021 | 09:12 PM
ahab's Avatar
I wired mine into power up near the sunroof motor feed in my Disco, which is always hot. It's a major PITA. If I'm not driving the truck for 4 or 5 days it will drain the battery when I forget to shut it off. Which is way more often than I had figured I'd be good for, even at my advanced age . My advice would be to find switched power.
Old Apr 5, 2021 | 08:56 PM
msgm1's Avatar
Yes original V1
Old Apr 5, 2021 | 09:22 PM
umbertob's Avatar
I piggybacked off the Air Ionizer fuse in the passenger compartment fuse box for my radar detector. The detector will turn on only when the engine runs (it will stay off with the ignition on but the engine not running.) If you are interested, I posted thread here: https://landroverforums.com/forum/20...nstall-102271/
I don't have a V1, but a fairly sensitive Uniden R3 unit that lacks the direction arrows of a Valentine but is otherwise every bit as sensitive. As you will see in the other thread it's mounted kind of low above the center dash, no false alerts. Built-in GPS works great there too and the solar attenuating windshield doesn't appear to affect sensitivity to radar detection. But yeah, as others have recommended even in the original V1 you should lock out K, X - perhaps even laser - and likely eliminate a huge number of false alerts without jeopardizing detection of real bogeys from you local LEO. Pretty much all self respecting law enforcement agencies these days use either laser (in which case you're toast anyway) or Ka band radar guns operating on very limited frequencies. There are even databases online that tell you what your local agencies are likely to use for speed detection.
Old Apr 6, 2021 | 06:50 AM
PaulLR's Avatar
Originally Posted by msgm1
Yes original V1
Here: https://www.valentine1.com/v1-detectors/upgrades/
Old Apr 6, 2021 | 07:03 AM
PaulLR's Avatar
[QUOTE=umbertob;768603]
Pretty much all self respecting law enforcement agencies these days use either laser (in which case you're toast anyway) or Ka band radar guns operating on very limited frequencies. /QUOTE]
On my LR4 I still have a 4-head ALP system installed. Back when I used to travel a lot to meet in person with clients it saved me so many times. And they provide frequent software updates as new laser guns come out. Highly recommend ALP if you need laser defense.
https://www.alpriorityusa.com/
But since the pandemic all my meetings are virtual so I won't be installing an ALP system in the Defender.
