Rear Brakes
Old Dec 4, 2024 | 03:47 PM
DISCOFETA's Avatar
Default Rear Brakes
Dealer was suggesting to change out the rear brakes, as life remaining looked low... but they wanted around $2,000 just for rear brakes. I actually could not get a clear answer if this was pads + rotors. Thoughts? '23 130 1st editiion
Old Dec 4, 2024 | 04:25 PM
Pete C's Avatar
I recently priced just rear pad replacement while at the dealership. I was quoted $329 FYI.
I have a ‘21 110 P400 with 39k miles as a reference.
Old Dec 4, 2024 | 05:25 PM
H1Tad's Avatar
The dealer up here in Maine told me that my pads were 50% worn after 30k miles on my 22, which I found to be a little disconcerting. Is there something magical about the calipers that makes doing the job yourself impossible with a caliper compression tool (aka vice grips)?
Old Dec 4, 2024 | 06:36 PM
Pete C's Avatar
Yes, there is a procedure necessary to deal with the electronic parking brake from engaging while your changing the pads. There is info about how to do that on You Tube, or I presume with a GAP4 tool.
Old Dec 5, 2024 | 01:53 PM
POPTOPP's Avatar
I've 80,000 miles on my '22 P400 110 and have replaced the rear brake pads twice. Both times, the dealership wanted to replace rotors as well for a total bill of around $2,000. In my case, there was zero need for a rotor replacement. I declined and did pads only saving a whole boatload of money.
Old Dec 5, 2024 | 02:18 PM
nashvegas's Avatar
That is 100% pads and rotors
Old Dec 5, 2024 | 08:36 PM
Vadiable Paradox's Avatar
...and labor
If Google doesn't lie, you can get stock rotors and pads for about $900 including tax, no? Then comes the know how, and the tools to do it.
Old Dec 20, 2024 | 08:15 AM
sacharama's Avatar
Parts are about $1000 if you get them yourself
Dealer markup will probably come out to be $1200
Labor is about 2.5 hours at $250 an hour in most JLR dealership, so that's $625
$1825 plus sales tax
Old Jan 6, 2025 | 12:14 AM
super50's Avatar
Is it the usual experience for the Defender to need the rear brakes done first?
Old Jan 12, 2025 | 03:54 PM
TrioLRowner's Avatar
YES. It's very unusual, I know.
It is at least partly the result of the electronic braking logic which applies the rear brakes before the front in order to stop the nose from diving -- keeps the vehicle flat through corners.
More comments from others, I expect.
Groucho123
Range Rover L405 (Fourth Gen)
Nov 11, 2022 01:57 PM
jbkroh
Mar 29, 2014 02:05 PM
krhodes
Aug 28, 2009 05:08 PM
mwsharb
Mar 9, 2009 02:22 PM
rirover
Jul 7, 2006 07:22 PM
