rear climate not working
Old Feb 6, 2021 | 10:03 AM
Tucker Woods's Avatar
In regards to the rear climate, does anyone else have issues (American models) with the temperature being reported in Celsius on the Pivi Pro screen for the rear climate? I would say 5-10% of the time when I am adjusting the rear climate from the Pivi Pro screen it is in Celsius instead of Fahrenheit (but on the actual dials in the rear seat, it is still in Fahrenehit).
2020 Defender 110 First Edition Indus Silver (Current)
2020 Discovery HSE Luxury Si6 Fuji White (Current)
2015 RRS Autobiography Fuji White (Former)
2011 RRS Supercharged Fuji White (Former)
2008 LR2 Fuji White (Former)
Old May 21, 2021 | 10:06 PM
Kalliste80's Avatar
Hi, Does anyone know how second row passengers can adjust the climate (i.e. fan speed, temp) without it interfering with the front row? The second row stays synced to the front row so if the kiddos blast the fan I get blasted too (I know I can close the vents but that’s besides the point). I don’t see an “un-sync” button on the PIVI pro screen, only “lock” and “auto”. Thanks in advance.
Old Aug 15, 2022 | 10:21 AM
DEFENDER2023's Avatar
4wd High
Hi, new here..!
Did you find a solution for this?
Second row can decide the fan speed for the front row all the time unless fully disabled controls...!?
Old Aug 15, 2022 | 11:29 AM
GavinC's Avatar
Sync is controlled by driver control only.
Passenger seat and second row can adjust their own temps and this will unsync the system and does not alter temps in other areas.
Similarly passenger can unsync and adjust their temp anytime without it impacting the driver temp.
The lock feature prevents second row from adjusting their own temps or fan speed. Passenger can still adjust.
Third row temps are dictated by second row temps. Third row can adjust their own fan. (Again, lock feature prevents this).
Old Aug 15, 2022 | 01:53 PM
4wd High
Yes that is correct, but how about the fan speed? second row puts the fan speed in 5, then front row also gets a 5 speed fan.
No way to have independent fan speed?
Old Aug 15, 2022 | 03:26 PM
GavinC's Avatar
Fan speed is similarly controlled/over ridden by sync. 2nd row adjusting fan has no impact on front.
Edit: This is 100% wrong
Old Aug 15, 2022 | 03:53 PM
4wd High
mine does... whatever happens with fan speed on the second row happens on the front row.
so any rear seat passenger that adjusts the fan speed also changes the front row.
Old Aug 19, 2022 | 05:39 AM
Dokodoko's Avatar
I have the same problem with the fan control... Can we confirm that it has 2 blowers? I kinda fear that we only get one, from the front and 2nd row.
Old Aug 22, 2022 | 03:29 PM
GavinC's Avatar
I thought there was a second row one but I was wrong. The second row passengers can indeed over ride the first row if it's not locked in the AC control.
3rd row has it's own separate blower that can be controlled by the third row. Sorry for the bad info.
Old Oct 1, 2022 | 06:35 AM
samnoho's Avatar
7th Gear
I am a little confused to what the answer is lol. Is the Front and second row on the same fan? Is there any way for them to be independent ?
