Rear Diff Clunk after Oil Change
Old Feb 27, 2024 | 07:01 PM
EchorecT7E's Avatar
Default Rear Diff Clunk after Oil Change
Hi all, had my rear diff oil changed by the dealer at 60k miles. Now, when pulling away from a stop, I’ll occasionally get a thud/clunk from the rear. Is this a cause for concern?
Old Feb 27, 2024 | 10:11 PM
mrmihai's Avatar
https://landroverforums.com/forum/20...-sound-114622/
Old Feb 27, 2024 | 11:36 PM
EchorecT7E's Avatar
thanks. Wonder if the dealer would double flush without additional charge since the problem is a result of their service. I guess I have no way to prove this though. Honestly it doesn’t really bother me, I just want to make sure it won’t screw something up
Old Feb 28, 2024 | 07:46 AM
Can_Glu's Avatar
are you sure the clunk is from your rear diff?
clunk is usually caused by two hard parts hitting each other. it worth closer check of its origin.
Old Feb 28, 2024 | 08:05 AM
EchorecT7E's Avatar
it’s not a clunk, more of a thud. Should’ve been more clear in OP
Old Feb 28, 2024 | 10:26 AM
Can_Glu's Avatar
clunk or thud, it must be caused by the relative movement between some parts.
It was not there before, that is good.
Now you hear it (!) that is usually not good.
It worth checking, just for the pace of mind or maybe you can catch some thing before it become worse.
Old Feb 29, 2024 | 05:29 AM
sarek's Avatar
This is becoming a bit more common on the factory locking differentials. The thumping starts mildly and then gets worse. It is possible the incorrect fluid was used, but the likelihood is that the clutches have worn inside the unit. Changing the fluid 2x seems to alleviate the symptom temporarily, however, replacement is the final fix.
Old Feb 29, 2024 | 08:04 AM
EchorecT7E's Avatar
clutch wear totally makes sense. What doesn’t make any sense is that this issue appeared right after the dealer changed the diff oil. It was totally quiet before.
Richard Gallant
May 12, 2021 05:43 PM
Snas2013
Freelander
Jun 5, 2019 12:26 PM
djkronik57
Jun 2, 2017 02:40 PM
WoodlandsLandRover
Nov 15, 2015 08:38 PM
springer6
Freelander
Oct 29, 2014 09:08 AM
