Rear View Camera/Dash Cam combos?
I installed the Blackvue Dash cam 2 channel like a few others here. Very good 4k video and high quality, unobtrusive hardware. I've been very happy with it.
Any info on the installation? Front and rear cam or just front? Tricky/easy? Did you tap into the hardware in the windshield or overhead console or run it to the fuse box in the engine bay?
So many questions
Looks like a fine product.
FitcamX looks really simple. I'd prefer to have a camera system I can use on future vehicles too.
@UtahLandy
So many questions
So many questions
GavinC (09-02-2022)
I installed the front and rear cameras using PowerfulUK's wiring harness and the install went very similar to Simon's LR factory unit install except the wire run for the rear camera was not long enough to run down the A Pillar, down along the bottom door jam so I just went from the A pillar above the head liner to the C Pillar and through the same conduit Simon used to the back door. It took about 3 hours for me after watching Simon's video a few times. If I want to swap this to a later vehicle I would leave the rear wiring harness in place, pull the power cable from the overhead console (quick and easy) and pull the two cameras. I would just order another hardwire kit for $15. I don't know anything about the Fitcam X but it sounds much easier to install, not that the Blackvue was hard to install, just time consuming figuring out how to disassemble some of the interior. Is the Fitcam 4K? I would say that is a must since I feel you really need that level of definition to read license plates in low light or less than optimal conditions. This along with Blackvue's Parking mode and its unobtrusive footprint were what swayed me to go that way.
https://www.youtube.com/watch?v=QpkeIp-tmLA&t=43s
So just so I'm understanding correctly. The powerful UK loom to tap into the overhead console means not needing the fuse taps from BlackVue?
I used the loom from PowerfulUK and it worked great no fuse tap needed. The length of the cable to the back camera was too short but I found a company on line that built a 5 foot extension which was perfect. BlackVue sells longer cables but after the work to run it there was no way I was doing it all over again
