Rear wiper replacement?
Bosch is my go-to brand. However, the OE Specialty Rear wiper, is incorrectly listed as a fit. It is a solid blade, not a suitable replacement for the integrated washer system of the factory blade. Note the washer line to the blade and the attached rubber tube with the spray holes. Unless I'm missing something from the Bosch site, I didn't see a replacement.
I have a 2020 110 X w/ cold climate pack, and the factory original wiper blades, so it's 2 years old & time to change wiper blades. 2 questions:
1) Need to remove the spare tire to change the rear blade (like on my old Discovery 2's which I always found annoying)? I can't figure out how to get the wiper blade off, the service manual shows just pulling it towards the window away from the arm.
2) I'd remembered reading this thread about the wiper blade being "special" to incorporate the squirters, so was expecting that when I went to change. However, when I opened the dealer part box, just a normal rear wiper. Just as I was about to get hot and bothered, I looked at my car, and indeed I have a regular blade with no squirt function, ie standard style squirter separate entirely from the blade. So that's good. (ie I have no tube connected to end of wiper blade and little micro holes in the wiper blade to squirt the water out, like the photo above). I googled this and it's called the Valeo Aquablade, used on Volvos etc. Did Land Rover try this and then abandon it on the Defender ? Or is this something that was added to later Defenders? Doesn't really matter just curious really.
GrouseK9 (01-06-2023)
It's times like this I wish @The Insider was still around. Many times people would ping him as if he were the JLR Grief Box or HelpDesk. I just liked his insights into the "why's". Regardless, I think we'll never know.
ficklma1 (01-06-2023)
I have an issue with my front wipers too. I had a bug hit my windshield on the driver's side, so I pressed the button for wiper fluid and it only squirted out a little, from each blade and never got and fluid on an entire section of windshield, directly in front of my face. Is there a known issue with this setup? This definitely won't be fun in the winter with salt all over the windshield.
