Rebooting a Defender?
Old Apr 16, 2023 | 08:28 AM
POPTOPP's Avatar
Default Rebooting a Defender?
Other than disconnecting the battery, is there a way to reboot our trucks?
Old Apr 16, 2023 | 09:09 AM
Ratledge's Avatar
Mine is being built next week, but I have seen something like holding the power switch on the radio 30 seconds? Someone will chime in and correct if needed.
Old Apr 16, 2023 | 11:24 AM
_Allegedly's Avatar
That will reboot Pivi. Afaik, disconnecting the battery is the only way to reboot every module in the vehicle. To me, a 10mm wrench is just as essential as a tire guage & code reader in the glove box.
Old Apr 16, 2023 | 04:42 PM
lightning's Avatar
Why would you want to "re boot" your Defender?
Old Apr 16, 2023 | 04:57 PM
POPTOPP's Avatar
My key fobs are no longer proximity recognized by the ignition system. The locking system continues to recognize them. I thought a "reboot" might clear the issue. (It's not a fob battery issue.)
Old Apr 16, 2023 | 08:15 PM
_Allegedly's Avatar
Old Apr 17, 2023 | 05:39 AM
lightning's Avatar
Okay, l can see that might cure the fault.
Old Apr 17, 2023 | 08:22 AM
SilverSFR's Avatar
I would still change your battery in you key Fobs then test again. It is an easy step to troubleshot. Its the first thing the dealership will do and might save you a trip to the dealer. When troubleshooting its best not to assume anything.
Old Apr 17, 2023 | 09:25 AM
POPTOPP's Avatar
Thanks, yep did that as my fall back step. No joy. However, magically the following day, everything is fine again. Go figure.
Old Apr 18, 2023 | 02:29 PM
Ronin Defender's Avatar
I just did a little test, if the engine is running while parked and a door is opened the key warning will pop up and not turn off until the engine is restarted.
The key is still on the center console ..
This happens every time even after the dealer replaced the module.
V8DEFENDER90EUROPE
Defender
Jan 14, 2023 11:23 PM
msgm1
Dec 10, 2022 10:17 PM
MattF
May 18, 2022 03:16 PM
exotic ltd
Feb 10, 2022 01:24 PM
DCH12
Jan 11, 2022 05:53 PM
