Removing dash trim help
Old Jun 10, 2023 | 09:00 PM
DefenderRR's Avatar
Default Removing dash trim help
Greetings everyone!
Need some help from you all. There is a squeaky noise coming behind this trim below (the foamy trim). If I push it down with my hand while driving it goes away. I am trying to avoid a trip to the dealer. I can put some felt behind it and will most likely fix it
Could someone please guide me how to remove the trim? I tried by removing the side panel, but couldn’t locate the right screw.
Old Jun 10, 2023 | 09:43 PM
smithbp's Avatar
@Saltek Motorsports shows how when installing their sp9100 mounting bracket.
https://saltekmotorsports.com/how-to...-installation/
Old Jun 11, 2023 | 07:29 AM
PaulLR's Avatar
Remove the 4 grab handle torx bolts and grab handle, then remove the one small black torx screw that comes in from the left side of the trim piece. Then just pull the rounded trim piece off toward you. There are 4 spring clips that attach it. I lined the back with adhesive felt and snapped it back on. All quiet. You can buy sheets of adhesive felt in the Walmart sewing department.
Old Jun 11, 2023 | 10:36 AM
DefenderRR's Avatar
Thank you @PaulLR and @smithbp. Problem solved. I can sleep better now 😊
heliochrome85
Aug 29, 2022 12:27 PM
austinlandroverbill
Mar 12, 2022 11:32 AM
RYAN3326
Mar 11, 2013 08:40 AM
cer308
May 16, 2012 09:33 AM
humroot
Aug 22, 2010 07:33 PM
