Reversing At Night + Touchscreen Brightness
Old Jun 5, 2021 | 10:16 AM
SUPper's Avatar
Default Reversing At Night + Touchscreen Brightness
Hi All, new member here.
Been lurking here a while and finding some great info as I worked up to buying my Pangea Green MY21 Defender P400 X (cold climate pack, towing pack, orange recovery eyes, all black interior, smoked dark oak veneer) that I received just last week. Ordered in early Feb. It was a P400 base that the dealer already had ordered for themselves, but they were able to tweak it to my spec. Super happy so far, no regrets other than perhaps going with 19" wheels and the limited tyre choice. (I simply like the gloss black look). I wish I had researched that a little better and in retrospect I should have gone with one of the grey 20" sets. Never mind... Weirdly enough my winter package rims will be 20"s with slightly skinnier rubber!
So I have 2 questions;
1) Driving home after dark for 1st time last night I reverse parked into my (admittedly quite dark) driveway and in the reverse camera view could not see very much at all and I just had to "use the force". I hear that the reverse lights aren't exactly bright (and I will check later that they are actually working). Just wondered if anyone else has the same concern. Side note, I see that Powerful UK actually installed a whole extra reverse light, and there's a video for it.
2) The touch screen at night is really dim (in both dark and light styles). Daytime is fine. I tried brightening using the onscreen slider but it changed nothing - in either direction. Probably I have engaged some other setting somewhere that disables brightness adjustment? Can anyone "shed any light"?
Cheers All. Here's a pic of the new machine. Pls don't kill me for the excessively wide roof bars, they're extra wide because I sometimes carry a fat fishing kayak along with a fat SUP or roof box plus I sometimes load from the side using straps across the protrusions as a cradle. These are Thule Wingbar Evos and I used the Thule.sa parts list to cobble together this assembly. North America Thule sites don't as yet have a Defender fitment it seems.
Old Jun 5, 2021 | 10:40 PM
charlypm's Avatar
I too noticed the light were not very bright when in reverse. I've order and installed the reverse light kit from PowerFulUK and very happy with it. It is a pretty quick and easy installation (the only revision is to cut the screws a little shorter so they don't scratch the paint) and could easily be removed with out showing any modifications. https://www.powerfuluk.com/vehicles/...grade-kit.html
I also bought the uprated rear area lights and the overhead LED light, what a difference that makes, highly recommend it.
https://www.powerfuluk.com/vehicles/...oof-light.html
https://www.powerfuluk.com/vehicles/...2pc-white.html
Both are very easy to install.
Old Jun 6, 2021 | 09:26 AM
sacharama's Avatar
sorry i don’t have any insights on the reverse lights or the touchscreen brightness as i am still waiting for mine to come. But i have a question regarding your Thule set up. What size/length of the wingbar evo do you have? Are they the 127 (50mm) or the longer one?
thanks!
Old Jun 6, 2021 | 12:58 PM
SUPper's Avatar
Thank you Charlypm, I'll take a look at those options.
Old Jun 6, 2021 | 01:05 PM
SUPper's Avatar
thanks!
Hi Sacharama, those are the 150 (60") width. Note: If anyone is considering using this width of Wingbar Evo, the slots underneath will need to be lengthened or they won't fit onto the podiums on the Defender tracks. The front bar was +/- 6-7cm had to get sawn out and the rear bar (because the tracks are converge towards the rear of the vehicle) even more. Measure twice cut once, and use at your own risk.
Penquinn
Apr 30, 2021 02:43 PM
dmo1028
Apr 11, 2021 08:52 PM
2020Defend3r
Apr 8, 2021 02:59 PM
SoCalWiley
Jun 18, 2018 12:59 PM
jlo3
Defender
May 24, 2015 12:55 AM
