Roof Top Tent/Roof Rack
Old Dec 23, 2023 | 09:04 PM
Jackr86's Avatar
Default Roof Top Tent/Roof Rack
Hi all. I have the stock defender 110 roof rack installed on my vehicle. I am looking to add a roof top tent for seasonal adventures. When looking at mounting instructions - it appears the Land Rover roof rack will not work according to Thule. Does anyone have any experience or insight on this, or do I need to just get a different rack set. Thanks for the help. Pictures for reference.
Old Dec 24, 2023 | 10:44 PM
Dogpilot's Avatar
The Land Rover Rack is not one of the type you re looking at. It is mounted to the track, not the edge or to a gutter. The issue with RTT's is when you go over a bump, it has quite a bit of down force on your rack. With the ones pictured they would tend to splay out and probably come insecure or come off entirely. The Land Rover is a track system, which is rated for I think it is 350 lbs static. I do not think you will have a problem with the RTT, unless it is over 350 lbs. Then it more, good luck getting it up there. Personally I use a rope & pulley hoist in my hanger to get it on and off. I think I am fortunate to be able to do it that way. Otherwise, you need a bit of a crowd to get them up there without damaging your roof. I do put some 1.5" closed cell foam on the roof, just in case while I install it.
Old Dec 26, 2023 | 12:14 AM
Jackr86's Avatar
Thank's so much... super helpful info. Merry Christmas!
Old Dec 26, 2023 | 01:37 PM
Myron's Avatar
I use the Camper Crane 2000 to get mine on and off my Front Runner rack/tray thing. Short of something like this or what Dogpilot is doing, you will definitely need at least one helper.
Old Dec 26, 2023 | 06:16 PM
mammoth's Avatar
I have the CVT Mt Hood (size small), and it's mounted to the LR expedition rack with the U brackets that were included with the tent. I chose that tent because it fit the dimensions of the Land Rover rack almost perfectly, and it was cheaper than the LR branded Autohome tent. No issues/creaks after a year of driving with it, I hardly notice it's up there. I had it installed by GTFOverland in Long Beach, CA - they used a crane to drop it on the rack. If you're in the area, I'd highly recommend checking them out.
slavb
May 4, 2025 01:58 AM
KamboMD
Jan 14, 2024 05:09 PM
SISU
Mar 25, 2023 07:13 PM
me 2
May 2, 2021 12:41 PM
LR03NJ
Jul 8, 2017 02:39 AM
