Routing cables from roof to trunk
@PowerfulUK has this video of mounting the Plumb side boxes:
During it, Simon shows a grommet that is up high. I'd try and use that. Although you might need a new panel, as they seem to break easily.
https://www.youtube.com/watch?v=QufLL9uTib8
https://landroverforums.com/forum/20...lution-105438/
I've pulled that panel on a couple of defenders now and haven't broken one. You could probably just glue it back together.
I'm not 100% sure, but I think you would have to drill the rail. I'm using the front runner rack without roof rails. It leaves a pretty big gap and I haven't had any water leaks. So I wouldn't worry about a adding hole to the rail.
thank you! So I can drill on through the top plastic of the back top panel plastic as the recommendation?
