Simple headlight swap L663 Defender
Old Mar 28, 2025 | 01:18 AM
GavinC's Avatar
Default Simple headlight swap L663 Defender
DRL repair
Swapped out my defective light for a new one.
A used one harvested from a Texas breakers yard.
$372.81 including tax and shipping and about an hour of my time. The one electrical connector took me a while to get off. A very simple job otherwise
Now I get to fix the old one with a replacement DRL module I got from Aliexpress. Less than $3 for the part.
Eye-patch pirate look
"New Light"
This connector for the front radar is fiddly.
Remove these
Remove these
Good as new
Good as new
$3 DRL module shipped from China
File Type: pdf
Old Mar 28, 2025 | 04:51 AM
AVLDefender's Avatar
Watch those Chinese chips. I put one in each of my headlights and 3 months later both were out again.
Old Mar 28, 2025 | 09:59 AM
GavinC's Avatar
I plan to keep the repaired one as a spare. Took apart the housing on it. Not the prettiest job but should be fine with a little JB weld in a few spots.
Module looks near identical to OEM. I'd not be surprised if it's the same supplier on all.
I figure at $3 I can take a chance.
Old Mar 28, 2025 | 04:44 PM
Melburnian's Avatar
It boggles the mind that the OEMs did not consider serviceability when engineering this for JLR :-(
Old Mar 28, 2025 | 07:09 PM
tbrown's Avatar
Does the Texas breaker have a website? Thanks!
Side note, I use Erie Volvo for our Volvo and they are pretty great. https://www.erievovo.com/
Old Mar 28, 2025 | 08:34 PM
GavinC's Avatar
It’s a bit ridiculous how the assembly comes together. Far more clips than needed
with the rubbery sealant. It could have been made similarly with a gasket and some clips. No major change in design. Just omit a few clips and use gasket not glue.
I suppose the trade off would then be a greater potential for leaks. A trade off I think most owners would be happy to take.
Old Mar 28, 2025 | 08:40 PM
GavinC's Avatar
I just went on eBay and looked for one that was a little less than perfect. This one has a barely there scratch on the lens. If I didn’t know it was there I’d never have found it. Meant for a good price.
loads on eBay.
the replacement light looks newer and cleaner than mine. Hopefully there’s some life in the DRL module.
not worried either way.
this is a very doable repair.
Old (I popped off one of the broken LEDs by accident)
New module. Loads on eBay. This was less than $3
New module. Loads on Aliexpress. This was less than $3
Disassembling and reassembling.
Blessed be the JB weld
Letting my repair set.
Old Mar 29, 2025 | 10:39 PM
GavinC's Avatar
All fixed and ready to go for it’s final seal.
I know, let’s remove any finger grease from the lens. Let me use that acetone.
instant cloudy lens.
im an idiot.
Old Mar 30, 2025 | 09:07 AM
tbrown's Avatar
Arghhhhh.... not acetone..... isopropyl alcohol!
Good luck getting that clear.
Old Mar 30, 2025 | 09:22 PM
GavinC's Avatar
it’s trash now. No buffing that out.
I need a new lens. About $90 on eBay.
